Singed Eyebrows said:
Every time you burn wood in your boiler you degrade the plates, more or less. To say that the wear is almost non existant or that somehow your boiler is not affected by this is incorrect in my opinion. It's there, it just takes awhile to show up. My Atmos has a 10 year life if operated properly. I was told & I believe I read a carbon steel Woodgun has a 10 year life. Each of these can exceed this under the right conditions. Even though you keep the boiler temps up you will still degrade the plates, it just takes longer. I don't attempt to make my points with funny faces & I feel the ridicule is beneath what is otherwise a classy poster. My original reply was to try to help a fellow Hearth member & I stand by what I said. Next! Randy
That could be said about oil and gas boilers just as easily, or fireplaces, and so forth - if you burn ANYTHING in a vessel, you presumably shorten it's life; by how much is a more complex question. I never said anything different. My opinion is that attempting to keep the temperatures of the metal as low as practical without going below the condensation temperatures, and consistent with maintaining secondary combustion will maximize the boiler life. There are also definite design factors to consider, as Piker mentions. (Among other examples see some of the threads on the recent Central Boiler failures due to exposing the steel to high temps in the gasification burner area - this appears to be a heat failure issue, not a condensation problem.)
Now I am not throwing stones at the Atmos, or the Carbon Steel Wood Guns, but I have gotten a distinct impression from what I've seen of the units, and their respective websites, that both are constructed as "economy" model boilers (especially the Atmos "G" models as opposed to the "GS" models) WG claims their stainless models have a 25+ year life expectancy, as in their oldest stainless models have been operational for that long... (This despite the way that the WG operating instructions encourage idling, which the other makers say has a bad effect on boiler life) Some of the other carbon steel boiler companies have been talking life expectancies in the 20-25 year range, when operated properly. Thus I wonder if the issue you seem to be suggesting with the Atmos is more due to the brand of boiler than it is the fact that it burns wood...
Another question that may also be relevant is what the "failure mode" is that causes these boilers to be replaced? Is it a failure of the boiler vessel or heat exchanger tubes? Or is it a question of other parts failing that are not worth repairing? Or is it just a general need to update, similar to the urge to turn in reasonably functional cars on newer models?
If it is a failure of the boiler vessel, then yes your question about steel degradation is an important one, since it has a direct impact on the boiler lifespan.
If the critical failure is in a different area, then steel degradation is somewhat of a non-issue since the boiler vessel outlasted the rest of the unit - just as putting a one million mile grade engine in your car won't increase it's life if the frame rots out at 500Kmiles...
This is a topic I haven't really seen addressed that much - perhaps some of our industry pro's can chime in and tell us what it is that is most likely to be doing in our boilers?
Gooserider
