I do not think that will work very well for you. The range is too large. I have a Dwyer 2000-00 with a range of 0 - .25. This one is would be much better for low draft readings.I got a magnahelic like this one 30$ shipped.
NIB Dwyer Magnehelic Pressure Gauge Model 2000-0 WIIH Series 2000 0-2" | eBay
Find many great new & used options and get the best deals for NIB Dwyer Magnehelic Pressure Gauge Model 2000-0 WIIH Series 2000 0-2" at the best online prices at eBay! Free shipping for many products!www.ebay.com
Agreed get the one with the 0-.25 “wcI do not think that will work very well for you. The range is too large. I have a Dwyer 2000-00 with a range of 0 - .25. This one is would be much better for low draft readings.
(got it a few years back for $20.00 shipped)
Saw this on ebay: https://www.ebay.com/itm/265779999068?_trkparms=amclksrc=ITM&aid=1110006&algo=HOMESPLICE.SIM&ao=1&asc=20200818143230&meid=29db29a6ee5b40858277dc3448b08bf8&pid=101224&rk=5&rkt=5&sd=265777436665&itm=265779999068&pmt=0&noa=1&pg=2047675&algv=DefaultOrganicWeb&_trksid=p2047675.c101224.m-1
Device that measures pressure. Almost always a differential pressure.What is a manometer?
The Dwyer needs to be tied in between the furnace and any type of damper...which the damper (baro, right?) should come with a diagram that shows where and where not to put it...here https://www.fieldcontrols.com/wp-content/uploads/2019/05/01575700_TypeRC_Rev_B_04-15.pdfSorry for the late reply death in the family but Thanks for the help everyone I got all the supplies needed to hook this thing up hopefully this weekend. How close to the furnace should the BD be or should it be closer to the chimney? I’ll post some pictures when I can but I’ve watched some videos and some say close to the stack others close to the unit itself so kind of confusing info. Anyways thanks for your help guys much appreciated
That was super helpful thank you! It didn’t have anything in the box at all just the BD. That being said I think I got it all setup just have to get some bendable copper tubing this week. So I guess final question does this setup look correct or did I do something wrong? Thanks guysThe Dwyer needs to be tied in between the furnace and any type of damper...which the damper (baro, right?) should come with a diagram that shows where and where not to put it...here https://www.fieldcontrols.com/wp-content/uploads/2019/05/01575700_TypeRC_Rev_B_04-15.pdf
You don't want it close to anything...in the middle of a straight section is best...and I have tried different positions on the pipe, didn't see a difference...probably because the velocity is fairly low.I ordered my Magnehelic gauge as mentioned above and plan on using 1/4 copper tubing from HD. I understand that it needs to be located between the barometric damper and the furnace, but have been seeing mixed reviews on if its better to be closer to the damper or the flue collar. Wanted to get an opinion based on my setup before I drill the hole. Also, does it make any difference if the hole should be on side or top of flue pipe?
A NPT to compression fitting will work fine.My other question is what fitting/tip would be best to secure the line to the pipe. I was going to just get a standard compression fitting, but thought it may not be snug enough in the pipe. Also starting looking at the static pressure tip A301 and A307 from dwyer.
Thank you for the quick reply! I have read several of your posts since joining the forum and I appreciate any advice I can get for a newbie like myself. I did a lot of research and called the company several times before ordering. In addition, I spoke to Micdrew (a fellow Marylander) to get his insight on his experience before ordering. I have only had my setup up and running for 2 weeks and after going off what the manual and the videos say regarding the barometric damper setting and hearing about experiences on this site, I felt that getting a manometer would really help me get things dialed in with a flue that is ~25 to 30 ft tall.You don't want it close to anything...in the middle of a straight section is best...and I have tried different positions on the pipe, didn't see a difference...probably because the velocity is fairly low.
As I may have already mentioned, I just bend the copper into an S shape and hang it in the hole, works fine.
What do you plan on using the pressure tip for?
Doesn't seem to, no.If I go this route does is matter which orientation that 1/4 copper pipe is facing inside the pipe or how far it is in the pipe?
