He also disassembled and cemented the stove several times, i guess, he should remove both 90 curves and further increase height of the flue, or one of the two curves 90 could remain?
A 45* elbow coming off the stove, and another 45 (or two angles adding up to 90) going into the thimble would be better than the 90 you have now.
These stoves breathe decently. Mine works well at 16'. You may have to add a little height to the chimney. Even if you can't find a stove guy to do it, a handyman probably could if you do some reading and understand what is required, and relay that info to him. It's not exactly rocket science..
Oh, the pipe just sets on there. Held by two screws. Zero signs of leakage there, no soot. That connection is the least of my worries.
Usually have to pull it off 1-2 times during the summer to let a dumb bird who somehow managed to wriggle down the chimney, out. Got smart last summer and just opened the cleanout so the bird didn't have to fly through the house to get out...
Are you saying there's a stainless 6" liner in the masonry chimney, all the way to the top?
I don't understand the "18x8" high masonry units." What are they?
There is some sort of custom insulated or double walled stainless liner in the chimney that extends about 18" past the top of the masonry. Dad put it in after they had a chimney fire which damaged the original terra-cotta(? orange clay material) liner. I have no idea where it came from or who sells it, all I know is it's "custom" not a standard size, so it's not like you can just monkey your way up there and stuff another length of pipe on the end to extend the chimney.
The main structure of the chimney is constructed of concrete masonry units. Like cinder blocks. They're 8" high and there are 18 of them counting from where the pipe enters the chimney to the top, plus another 18" of stainless that extends above that.
