This spring I bought a old IH running gear with a hyd dump bed on it for $150. I have been working on it off and on and now its getting close to being done. This is what the wagon looked like when I got it. Other than the front tire was blown out and the spindles froze up. So I threw a old ford aluminum rim on it that fit.
Thats my Dad and Brother looking at it
Here it is after I got the bed off of it and was pulling it apart to clean it up and paint it.
I got it primed and painted
The IH running gear had to wait for a few other projects to get done. But I am moving on it again. Me and my brother cut down a big spruce and sawed it up for all the lumber for the new deck. Then my friend Scott said tamarack would be a lot stronger. So I went out found some of that cut it down and sawed it up for the beams and am just used the spruce for the deck. I painted all the lumber first so would be painted all the way around.
I made the deck 7'x15' with ten cross members for it. All bolted together. My brother Timmy is going to make me stake pockets for the sides front and back when I give him dimensions of what I want. I only went 7' wide as I am going to be using it in the woods and not for hay. And the stake pockets are going to add at least 2" per side.
It has pretty good lift for something made in the 50's. My friends dad said I should shorten it up and make it lift higher but I have it mostly together now and am leaving it that way.
My friend Scott gave me some rubber roofing materiel to put between the deck and cross beams and said it really helps to keep the beams from rotting out. He said to use it between the cross beams and main beams but I painted it and used lumber adhesive between them and that should keep the water out.
Rudi:
I almost did it you way. I gave it a test lift after I got the main beams on and broke a hose and it sprayed the main beams. I was going to coat the rest with oil and just paint the top but Dad wanted me to paint it all white so I did. But now that its done painted I think it would have looked better with the beams just coated with oil. And I was worried about coating the deck as I was worried about it getting slippery and I plan on using it to give wagon rides in.
Billy
![Dump Wagon Dump Wagon](/talk/proxy.php?image=http%3A%2F%2Fsphotos.ak.fbcdn.net%2Fhphotos-ak-snc4%2Fhs044.snc4%2F34549_1256025295704_1681757389_486778_2271839_n.jpg&hash=9d83ec0db37049e6b08104d82a03e36b)
![Dump Wagon Dump Wagon](/talk/proxy.php?image=http%3A%2F%2Fsphotos.ak.fbcdn.net%2Fhphotos-ak-snc4%2Fhs128.snc4%2F36786_1256022535635_1681757389_486776_6609032_n.jpg&hash=d248c75686aa4ca19b37b8bf2d406760)
![Dump Wagon Dump Wagon](/talk/proxy.php?image=http%3A%2F%2Fsphotos.ak.fbcdn.net%2Fhphotos-ak-snc4%2Fhs108.snc4%2F35752_1257186124724_1681757389_488416_5237421_n.jpg&hash=7e0d218a4eddec40190a0777bc6d1fd5)
![Dump Wagon Dump Wagon](/talk/proxy.php?image=http%3A%2F%2Fsphotos.ak.fbcdn.net%2Fhphotos-ak-snc4%2Fhs808.snc4%2F68855_1349341188543_1681757389_669125_3705493_n.jpg&hash=980d39867182b0a5fa42569757a5ac94)
![Dump Wagon Dump Wagon](/talk/proxy.php?image=http%3A%2F%2Fsphotos.ak.fbcdn.net%2Fhphotos-ak-ash2%2Fhs410.ash2%2F68855_1349341228544_1681757389_669126_5248864_n.jpg&hash=6a5b27bdea5645831a14404f7198c53d)
![Dump Wagon Dump Wagon](/talk/proxy.php?image=http%3A%2F%2Fsphotos.ak.fbcdn.net%2Fhphotos-ak-ash2%2Fhs410.ash2%2F68855_1349341268545_1681757389_669127_8053672_n.jpg&hash=f1f566e30b8aac38b77f54c6433e0b6d)
![Dump Wagon Dump Wagon](/talk/proxy.php?image=http%3A%2F%2Fsphotos.ak.fbcdn.net%2Fhphotos-ak-ash2%2Fhs410.ash2%2F68855_1349341308546_1681757389_669128_8221791_n.jpg&hash=e10e84632c08d23289dcc0cf12f53f9a)
Rudi said:Billy:
What I have found though, is that if you use even engine oil like 30 wt but apply a coat every year or two then the timbers will last much much longer. Mostly cause the water does not penetrate at all and simply beads. With paint - the smallest crack will allow moisture in and then it will collect and bubble up under undisturbed paint and rot the underlying wood. I have some PT spruce that I used for my little log wagon almost 10 years ago. I redo it with 30wt every couple of years. No rot whatsoever. We have another wood trailer made from tamarack that Dad has had for about 25 years or so. He coated it with Irving's finest 5w30 and it is still in pristine shape :D
Rudi:
Billy
