I have a new PE T5 Alderlea and am using Selkirk DSP (double wall stove pipe). I have used single wall stove pipe in the past to connect to the flue collar which is very easy to install.
My question is: when I side the DSP pipe damper section over the flue collar, the pre drilled holes on the outer DSP drop below the pre drilled holes in the flu collar. If I line up the holes, the inner part of the DSP fits loosely in the flue collar. So do I completely seat the DSP damper section on the flue collar and drill holes in the outer part of the DSP, then run self tapping screws from the flue collar into the inner crimped section of the DSP like you would single wall?
Or would I tap the holes in the flue collar and use bolts through the outer wall of the DSP?
I’ll put up a couple pictures.
Thanks in advance
![[Hearth.com] DSP to flue collar ? [Hearth.com] DSP to flue collar ?](https://www.hearth.com/talk/data/attachments/311/311787-372fdae516ad1e9870d2b119c2a6035d.jpg?hash=a1mUYeiIm0)
![[Hearth.com] DSP to flue collar ? [Hearth.com] DSP to flue collar ?](https://www.hearth.com/talk/data/attachments/311/311786-06f7381e99e973af108b74ee2e4396e6.jpg?hash=CbXYJV-BqU)
![[Hearth.com] DSP to flue collar ? [Hearth.com] DSP to flue collar ?](https://www.hearth.com/talk/data/attachments/311/311785-a0bb5c31d352581f5c1475c532b58fc9.jpg?hash=XEyPakskl2)
Thanks in advance
