Update: I did all the break in fires and had a first prolonged burn on Tuesday.
Beginning temp: 67
Burn length: 5 hours
Temp after 2 hours: 71
Wood: 4 oak splits/kindling
My concern now is the uninsulated poured concrete walls sucking heat. But all but 2' of the center chimney is within the basement. The east perimeter is two sections of cinder block and 2.5" thick aluminum sliding doors (separated by the chimney), i assume filled with foam board.
The south wall abuts the 25' x 12 patio, so it's not against the "outside", idk if that matters. The coldest I've measured in there was 58 in the dead of winter.
Upstairs, I noticed a 2d difference in the floor temp above the stove area.
Beginning temp: 67
