- Feb 4, 2007
- 9
What a great forum! I hope you are all toasty warm. I am NOT, and I need some serious help.
I am not new to wood burning; I have burned wood for more than 20 years in pre-existing (to me) stoves and chimneys with never a problem, until I installed a Drolet Adirondack stove in my apx. 1500-sq/ft A-frame three years ago. I have had the chimney reworked three times, the last by the most reputable firm in 100 miles. It draws beautifully, never backdrafts, warms quickly. I have two problems. One with everything closed off but the main room I can't heat above about 60 in extreme cold with the assistance of two elec. space heaters (it's 8 out now, 56 inside with a hot fire) and, worse, it needs a cleanout every one to three months, depending on how much I burn. I have heard everything from Drolet rules to Drolet **** (doesn't rule, fill in the blank). It is an EPA non-cat with baffles, and the creosote flakes down the pipe onto the top of the stove above the baffles, obviously choking it off. I just cleaned it a few weeks ago and I can hear the "rain stick" effect of creosote tinkling down the pipe as I write this. I got a large drafty cabin that was all window walls up to 56 in similar weather with nothing but a Heatolater fireplace! I burn bone-dry hardwood only, no paper, etc. I never let it smolder, never "bank" at night, get up every few hours to redo another decently hot fire. The glass is clean as a whistle. I wouldn't care about the cleanout, except the chimney is supposed to "telescope" to let me do this -- ha, that part has been reworked twice and it still takes me two hours to work it 1/4" off the collar. The house is insulated and weatherized, but not overly so. I didn't even need a fire the entire month of December (down to 30s). I'm afraid I'm going to have to let it go cold and clean it in the next couple of days. I have also been told the new EPAs are nothing but headaches. What gives? Any ideas? Thank you!
