Drolet-45 High temp alarm..shuts off on 3 setting
fixed. went up to camp put everything together and punched in the code. glad I didn't stay overnite. registered -30 this morning.
Yes. I do have 2 of the snap disks. I must have an older one. I have reset them many times with same results. Which one is causing you issue?
How did he tell you to bypass it?
I didn't have to by pass it but if u need to its pretty simple when u look at it. in the hopper theres a flanged plate that's held by screws. underneath is where the othe snap disk is. the newer 45's im not sure which snap disc they eliminated. top of auger or bottom? when I go back to camp overnite ill put it to the test to see if I get the same problem u r having.
