Hi, first post here. I have lurked as a guest reading what I could to setup my insert. After setting up all the pipe and it working well I took the advice of sealing up the hearth right above the insert. That was a lot of custom fun, taking everything out again and laying on my back with sheet metal and rock wool all over again. It definitely increased the efficiency of the whole system though. Now we have some more questions regarding the brick/cinder.
We installed an insert into an existing chimney, it's been working great and pumping out consistent nice heat for about 2 years now. It is located on an interior wall so the side the hearth is open to gets great heat. I just bought a DC ceiling fan that would sit right in front of it to move the air around better. It still takes a while to reach the other side of the wall. The wall has opening on both ends and you can run around the house (kids do) in a circle pattern all day. The fireplace is on the 2nd floor. There is a nice brick hearth around the fireplace with cinder block going to the basement (original fireplace ash cleanout) and all the way up to the roof. The roof has brick above the roofline.
What we have been thinking is making a hole in the masonry right behind the insert and of course below the hearth seal/smoke box I custom installed. We would have a fan connected to the inserts temperature controlled fan, and would blow hot air to the other side of the wall. The wall would be properly setup for the temperatures of course as it is drywalled now and you cant tell there is a chimney from this side. What we are wondering is how the hole would affect the vertical strength of the wall and how much heat would we actually gain from this ? We were thinking a round 4 -6" hole with a fan place inside the hole or inside stovepipe in the hole.
Having seen double sided hearths - that would be great and a dream setup, but an engineer, lots of masonry work and many dollars would need to be brought in to open it up that big !! It just sems a waste to have all that heat so close yet so far to the wall in backs onto.
Any thoughts on this?
