Going into our 3rd year burning... new stove, new through-wall chimney, new operator. I think we have poor draft, but don't know how to troubleshoot anymore or fix it.
I've burned ~1 cd each of the past 2 winters. Two chimney sweeps have confirmed no excessive creosote. They both said the install looks fine, but if we have draft problems they would install one of those spiral wind caps to prevent down drafts. I don't think that's it because this is always a problem, and no worse on windy days.
Last year someone here suggested stack effect, and our leaky attic "fighting" the chimney. We got the attic air-sealed and insulated over the summer. It makes a big difference in keeping the house warm, but the stove still streams smoke into the room.
We have zero confidence in the original installer since they shoddily slapped everything together without doing any site or room planning, so it feels like I need to figure it out myself unfortunately.
Any advice?
Thanks,
Dan
![Draft problems? Draft problems?](https://www.hearth.com/talk/data/attachments/321/321904-844fa067e76e1fced75d320a7f6b7c0c.jpg)
photo credit: https://www.northlineexpress.com/help-pipe-install-planning.html
- If the stove door is open, we'll get continuous smoke into the room
- Doesn't matter when in the burn cycle
- Doesn't matter if the front exterior door (same room) is wide open
- Doesn't matter if I leave the stove door cracked for a few minutes beforehand
- We commonly have a strong cold downdraft
- Downdrafts are stubborn - even lighting newspaper in the flue will still push smoke into the room
- Slightly worse with the bathroom fan or boiler running, but it's a problem even when they're not running
- Recently I noticed the smoke usually lingers in a ball around the chimney cap and tends to drift down.
Any advice?
Thanks,
Dan
