Has anyone had failures on the draft "damper actuator"? I had an original Neptronic fail on 12/1/08. I got a replacment Belimo LF 120 US on 12/3/08 and it failed yesterday, 12/15/08, the coldest day of the season.
I have my draft propped open about an inch so I can get heat out of the boiler, but of course it turns on the overtemp dump and it burns a lot more wood.
Has anyone had similar issues with the Belimo? It does have a 5 year warranty but that does no good if it fails and I have to wait a day or two (maybe longer if it fails on a Friday) to get another. No one around me sells a damper actuator even though we have 3 plumbing/hvac supply houses here. The sales rep where I bought the replacement said that it is very uncommon for these to fail... I don't know if that is true so I am asking here. They are sending me a new one but I think it may be getting too hot in the back for this unit. It is rated for up to 120 degrees so it may get hotter than that if it is firing hard. I do have a plate between it and the stove with some insulation in between. Maybe I need to insulate more around the unit or extend the shaft so the unit sits out from the boiler. I will be putting a temp sensor down there to record the max temp to see how high it goes. Just wondering if anyone else has had issues. It sucks for the boiler to go down when the night is -10 below with a daytime high of 9 above.
Do I need to keep a spare around? They are about $150 with shipping.
