I'm not saying this to hurt any feelings but it needs to be said. If you're this "hung up" on something as insignificant as combustion fans you're really going to be in the mud when it comes to making decisions during your install.
You may be a little misinformed if you are thinking that induced draft doesn't allow smoke to enter the room through the door gaskets. Whether forced or induced, the air is expanded probably more and adds more pressure to the firebox during the burn than the fan does. Whether forced or induced, it's the draft that takes the gasses away as well as contributing to combustion. It's not like the fans are there to blow fire up the tubes. Wood Gun installs a huge smoke flap over the loading door to keep smoke from rolling out into the room. On the 'Gun that I had, leaking door gaskets was one on my biggest problems.
The air injected by my forced draft is barely enough to blow a feather away.
IMO it is just another thing to consider. Not having to worry about door gaskets & smoke roll-outs may be favoured feature to some. I know I like not having to worry about that with mine, and all else being equal I would likely pick induced over forced. I would not pick induced over forced if the forced had other features that I thought more favourable.
No gaskets? Just steel on steel.
In the middle of a burn when my boiler is going 'hell-a-hoopin' I can slowly open the door after opening the bypass and the fire will continue to gas downward and won't even turn around and burn upward. This has to be driven by the natural draft.
I doubt that anything would be any different but I'll let you know. The combustion air for the perpetual burn is coming from the open door.What happens if you don't open the bypass first?
What do you have for chimney?
Negative Pressure: BioMass, Attack, Froling, Effecta, Garn, Woodgun
