Hello,
I've been lurking for quite a while, and now I need some help! I recently installed a Sierra wood stove with a 6" outlet. My chinmey is used for our oil furnace, so I needed to install a liner. My flue is 6" x 11"(?) ID, and I thought I could drop in a 6" flexible liner inside the flue and use both fuels and they would both have separate chimneys.
Well, things did not go as planned. I got most of the liner throught the flue with lots of pulling, but when we got most of it down, the top 10' section got pulled apart. We couldn't pull the rest of the 20' back out, so we removed the 10' top section and installed the liner to the stove. The stove is working fine, but the liner is partially blocking the pipe where the furnace vents into the chimney. Also, the flexible liner snakes up the chimney and surely blocks the furnace from venting properly. We only use the furnace as a backup, but it does come on in the early morning.
Here are my questions: how bad is my current situation? Can I remove the 6" liner and replace it with a 5" liner reduced at the stove? I'm wondering how this is affecting my furnace- it seems to be drafting well enough, but will it cause damage to the furnace or worse, damage to the house/us?
Thanks so much for the help![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
Brad
Brad
