As a firefighter, I would encourage anyone looking to do an exterior Class A chimney installation to first make sure they go with a chimney that meets Canadian specs as the pipe is better insulated, some is even 2" thick. The new DuraVent DuraPlus HTC meet these specs and is vast improvement over DuraPlus which I wont sell to anyone north of Florida. Next go to the NFPA website, (National Fire Prevention Association) website and see if you can find the National Statistics for home fires related to chimneys. I don't have that info in-front of me and were swamped so I don't have time right now to look it up, maybe latter. Saw the data a year or so ago and was amazed at how many home fires we caused by wall thimbles verses straight up through the roof. They attributed it to the fact that the creosote builds in the horizontal pipe in the wall and the fact that the smoke has to do a 180 degree turn before it goes up the chimney which is cold when you first fire the stove and will condensate as it heats up creating creosote issues. When a chimney fire does start, the risk of the elbow inside of the home melting increases with every minute the chimney is burning, once it burns through you literately have a rocket engine inside your home burning from both ends at over 2000 degrees
!! A sure fire way to burn a house down before the local fire dept can respond. I will no longer do any through the wall installations or those types of chimney sales unless there is no other way to do the job, then I spend a great deal of time with the customer teaching them how to properly clean their own chimney, if they wont clean their own chimney, I'll pass on the sale. The worst thing that generally will happen to a through the ceiling type of installation during a chimney fire is the chimney cap melts and falls off and rolls off the roof starting a fire in the shrubs on the outside of the house, a far better option if your have to have a chimney fire in my opinion. This is because there is not restriction in the pipe and the flames, sparks and heat take the path of least resistance and blow out the top of the chimney stack, the pipe does not get as near as hot as one with elbows which trap the heat. Most folks would rather go through the wall because they are afraid of a rood leak around the flashing. In thousands of installations i have done in my career I have never had a call back for that problem. A properly install roof flashing will not leak, even installed in a metal roof with heavy snow loads. Being in the Hearth business over 33 yrs. now looking back I can safely say that 90% of the folks that call me with smoking and drafting issues had some form of an exterior installation. I just had a customer called with questions so I did a quick search and as usual my friends here at Hearth.com were already on it here on this tread, so I thought I'd drop in add my two cents and say hi! Thanks for all you guys do to help folks get a safe install, the firefighters of the world applaud you!
Blessings!
!! A sure fire way to burn a house down before the local fire dept can respond. I will no longer do any through the wall installations or those types of chimney sales unless there is no other way to do the job, then I spend a great deal of time with the customer teaching them how to properly clean their own chimney, if they wont clean their own chimney, I'll pass on the sale. The worst thing that generally will happen to a through the ceiling type of installation during a chimney fire is the chimney cap melts and falls off and rolls off the roof starting a fire in the shrubs on the outside of the house, a far better option if your have to have a chimney fire in my opinion. This is because there is not restriction in the pipe and the flames, sparks and heat take the path of least resistance and blow out the top of the chimney stack, the pipe does not get as near as hot as one with elbows which trap the heat. Most folks would rather go through the wall because they are afraid of a rood leak around the flashing. In thousands of installations i have done in my career I have never had a call back for that problem. A properly install roof flashing will not leak, even installed in a metal roof with heavy snow loads. Being in the Hearth business over 33 yrs. now looking back I can safely say that 90% of the folks that call me with smoking and drafting issues had some form of an exterior installation. I just had a customer called with questions so I did a quick search and as usual my friends here at Hearth.com were already on it here on this tread, so I thought I'd drop in add my two cents and say hi! Thanks for all you guys do to help folks get a safe install, the firefighters of the world applaud you!Blessings!
![[Hearth.com] Double Wall vs. Triple Wall Class A Chimney [Hearth.com] Double Wall vs. Triple Wall Class A Chimney](https://www.hearth.com/talk/data/attachments/114/114482-77f8fb4ebee0729ecbb8539f16e61a90.jpg?hash=Z7wiDsUBYC)
![[Hearth.com] Double Wall vs. Triple Wall Class A Chimney [Hearth.com] Double Wall vs. Triple Wall Class A Chimney](https://www.hearth.com/talk/data/attachments/114/114483-a8b842f40197737e4c10f73b579c44a5.jpg?hash=1p2oOp0zWT)
![[Hearth.com] Double Wall vs. Triple Wall Class A Chimney [Hearth.com] Double Wall vs. Triple Wall Class A Chimney](https://www.hearth.com/talk/data/attachments/114/114484-979f9420fa87504689400b9258bbe373.jpg?hash=20URTfmwf6)
![[Hearth.com] Double Wall vs. Triple Wall Class A Chimney [Hearth.com] Double Wall vs. Triple Wall Class A Chimney](https://www.hearth.com/talk/data/attachments/114/114485-aa7efbf2ae93225533e870371740b891.jpg?hash=KEnuMwJP-H)
![[Hearth.com] Double Wall vs. Triple Wall Class A Chimney [Hearth.com] Double Wall vs. Triple Wall Class A Chimney](https://www.hearth.com/talk/data/attachments/114/114486-a1a9f2f65f61bc1814c22c00bf535d39.jpg?hash=ZFv_jjIoMq)
![[Hearth.com] Double Wall vs. Triple Wall Class A Chimney [Hearth.com] Double Wall vs. Triple Wall Class A Chimney](https://www.hearth.com/talk/data/attachments/114/114487-ec9a164bab64c4a4e623cb1faad04d6e.jpg?hash=xwR9cMeAju)
![[Hearth.com] Double Wall vs. Triple Wall Class A Chimney [Hearth.com] Double Wall vs. Triple Wall Class A Chimney](https://www.hearth.com/talk/data/attachments/114/114488-cde153460b7852572b9f60b3c520d022.jpg?hash=YLsFJ9t5sm)
![[Hearth.com] Double Wall vs. Triple Wall Class A Chimney [Hearth.com] Double Wall vs. Triple Wall Class A Chimney](https://www.hearth.com/talk/data/attachments/114/114489-543845af4fee32eed1bdb89e6e8ca364.jpg?hash=8upo3rsQk0)
![[Hearth.com] Double Wall vs. Triple Wall Class A Chimney [Hearth.com] Double Wall vs. Triple Wall Class A Chimney](https://www.hearth.com/talk/data/attachments/114/114490-b154fdd6fcae4439c7b844ea1d587e24.jpg?hash=d62Bstgvmu)
![[Hearth.com] Double Wall vs. Triple Wall Class A Chimney [Hearth.com] Double Wall vs. Triple Wall Class A Chimney](https://www.hearth.com/talk/data/attachments/114/114491-473f4254fcc8ee7e72de06e3b0fc7a6b.jpg?hash=8za8X5LXGU)
