That's surface temp. The flue gases are more likely around 450-500F.The stack is supposed to be 500F? When the stovetop on my 30 is about 550 F my single wall stove pipe is about 280F Am I doing something wrong?
Nope you are doing good pretty good. You pipe might be just a little cool so i would watch the stack but sounds pretty goodThe stack is supposed to be 500F? When the stovetop on my 30 is about 550 F my single wall stove pipe is about 280F Am I doing something wrong?
One is designed by the engineers that developed the heating appliance. The other is just pulling off a random unknown amount of heat off of the venting system.
I assumed that was with a probe and it is now way to hot but to hot for sureDid you guys assume I said that surface temps were 800? That would be very hot.
Yes and most furnaces i work on are a mess of creosoteThe furnace guys deal with much lower flue temps. Kuuma especially run only mid 300s internal which is sub 200 surface temps.
You do realize i work on chimneys every day. I see the real world results of many of those technologies. Some of them work well cats and true gassifiers but many just make a huge mess of the chimney when you extract to much heat.Once you realize how many technologies reduce flue temps to gain efficiency, you become more comfortable doing the same.
I think he agreed the stack is more efficient with the single wall. I argue that as long as the stove performs properly, that means the whole system is more efficient. I am totally on board with the idea that if pulling that heat from the flue gasses causes problems, forget it and go with double-wall. But for me, it does not cause problems: I do not get smoking when I open the door (unless I jerk it open suddenly in the middle of a burn cycle without turning up the air intake beforehand), and my chimney requires cleaning less than once per year. I guess I might could be convinced that somehow the stove itself would operate more efficiently with double-wall - even given that I clearly have adequate draft without it - enough to make up for the loss in stack efficiency.I think we agree but you just don't like the idea of removing heat from flue gasses to extract efficiency or increase maximum output.
No if you have to say it is more efficient one way or another due to the fact that the purpose of the venting system is to remove the products of combustion as quickly as possible while loosing as little heat as possible then double wall would be the more efficient choice. Yes i know very well it can be done just fine while loosing heat off the pipe but as a general rule that is not a very good approach.I think he agreed the stack is more efficient with the single wall.
I disagree with you on that completlyThis is tripping you up. That last part about "while loosing as little heat as possible", is not the purpose of a venting system. Actually, the "as quickly as possible" part is not true either.
I hate to get into "he said, you said" but in post #17 you state "Yes less heat up the stack is more efficient".No if you have to say it is more efficient one way or another ...RustyShackleford said:I think he agreed the stack is more efficient with the single wall
Well stated. I think what's he's trying to say if that if it's "too slowly" and "loosing too much heat" then the chimney won't perform properly (bad draft, smoking when opening door, creosote buildup).This is tripping you up. That last part about "while loosing as little heat as possible", is not the purpose of a venting system. Actually, the "as quickly as possible" part is not true either.
yes i know but that pipe is part of the stackI hate to get into "he said, you said" but in post #17 you state "Yes less heat up the stack is more efficient".
I never said you where not fine with single wall in fact i said the opposite that single wall is fine in short runs with stoves that can handle loosing some extra heat through the pipe. But saying it is a good idea to rely on that pipe to increase the efficiency of your stove is just wrong. And i am positive i know what bkvp will say why do you think their manuals call for double wall.But he can't seem to acknowledge that if the flue performs properly, then you're fine with single-wall, and you DO get more heat from a given amount of wood - which I call "efficiency".
ok fine they recommend it i misspoke. But after seeing thousands of different setup i can tell you that those with longer runs of single wall pipe have more creosote buildup generally than those with longer runs of double wall. In short runs of pipe or with less efficient stoves the problem in not as noticeable but the principle still stands that loosing to much heat from the venting system will cause more buildup in that venting system. I never said single wall was bad it is just fine in the right situation but in general double wall will make your stove run better and cause less buildup in the chimney.The BK manual does not require double wall. Recommends, sure, but that's not the same as requires.
Fair enough.I never said single wall was bad it is just fine in the right situation but in general double wall will make your stove run better and cause less buildup in the chimney.
