Door Removal / Jotul F600
Prich
2
CT
Hello,
Does anyone know if it is possible to remove the door off of a Jotl F600. The stove is probably about 24 years old and needs to have one of the holes which holds the bolt / clip assembly, which holds the glass in place, re tapped. The bolt has been sheared off but I was fortunate enough to track down a new piece of glass.
Thanks for any insight into this.
  • [Hearth.com] Door Removal / Jotul F600
Talk to one of these guys...
Might be the same as the F12. If so, there are bolts that hold it in place. Here is a tip for that stove.
Reactions: Prich
