ambull01
Well I think you said you're a blond..that should help..maybe better to shave your head?
Nah, I'm not blonde just act like a stereotypical one at times. I have black hair. Half Asian man in a west-east land.
Think of the fire box as being insulated the thicker it is,more insulated..where is the heat going to go when it the transfer rate is slow? I would think up the flue.Why do you think by storing the heat in the stove you are loosing more up the flue? A higher thermal mass stove wont loose any more heat up the flue than a comparable steel stove not sure why you think it would?
Think of the fire box as being insulated..where is the heat going to go when it the transfer rate is slow? I would think up the flue.
Heat transfer happens faster when the temp differential is the greatest.
Ok, here is my experiences with the glass door, upon reaching the coaling stage, when I open the glass door for a 5-10 minute time, I can raise the room temperature up significantly, especially with higher btu wood like red oak, I have been thinking lately that the glass door actually inhibits the transferring of the heat to the room, I'm usually always using my blowers thinking that is what is transferring the heat, not the glass.....
When the stove is burning good put your hand in fron of the glass then the steel right next to it..which place made your hand hotter.Ok, here is my experiences with the glass door, upon reaching the coaling stage, when I open the glass door for a 5-10 minute time, I can raise the room temperature up significantly, especially with higher btu wood like red oak, I have been thinking lately that the glass door actually inhibits the transferring of the heat to the room, I'm usually always using my blowers thinking that is what is transferring the heat, not the glass.....
If that were true, you'd be better off installing a traditional fireplace.
While you may feel the direct radiant heat of the coals with the stove door wide open, what you don't see is the huge volume of warmed air from elsewhere in the home that is getting sucked up the flue.
It's better to keep the door closed, despite what it may feel like with it open.
It's all about marketing my friend and to what pleases some eyes..they are pretty.Okay, finally figured out you're an engineer or something. I'm hoping you can explain one thing to me. I looked up thermal mass because I majored in accounting. So, according to what I read, the properties required for good thermal mass are:
High specific heat capacity and high density
I clicked on heat capacity and read it is the ration of the amount of heat energy transferred to an object and resulting increase in temperature. So soapstone sounds like it has a low heat capacity but does it make up for that with high density? Is radiant heat really inversely proportional to emissivity? I don't see anything that says that. Also why use soapstone at all if it's not inversely proportional to emissivity when steel will heat up faster!? This is so confusing.
Don't worry about all the fancy terms..just think it about it reasonably.
The one thing you kinda need to know is that heat transfer happens the fastest when the temp diff is the greatest.
Fans blowing on a stove can cool the medium..so when that happens the medium can gather more heat faster to transfer to the room..simple right? Also the fans did not change the fire in the stove any...at least not in a measurable way.
You're right. That said heat does get trapped in the back of a insert also so the fans help get that heat out into the room plus the fans do cool the steel so the steel can absorb more heat faster..Oh yeah that makes sense. So the insert fan is to cool the stove, check. I guess the reason for the insert fan is due to the fact they are restricted in which way they can vent heat (from the front). Thought the fans pushed out heat but that doesn't sound like the case. Free standing stoves wouldn't need this function as much because they freely radiate heat from all sides so there's less chance of over heating your stove. Am I right or totally off base?
A wood stove with 1ft thick steel surfaces would lose more heat to the flue then the same exact stove with 1/4 steel inch surfaces..it would have to right?.
The area intended for the insert is closed off, so no warm air is being sent up the flue
Emissivity is inversely proportional to heat density. Think of emissivity as the rate at which a given material will pass/give of/ radiate heat. So a soapstone stove can store the most heat but releases it at a slow rate. Glass stores minimal heat but releases it almost instantly. Steel stores a good amount of heat but releases it at a rather fast rate also, but nowhere near as fast as glass obviously.
No it wouldnt it would loose exactly the same amount why would it change it would take allot longer for you to feel the heat but it would be going into heating that mass of steel not going up the flue
Yes it is. You're getting heat directly from coals that are really hot but the room temp will drop soon.The house us not cooling down due to this action.
Man this stuff is interesting. I'm going to read up on this subject.
So if it is inversely proportional, why not use silver/polished copper/aluminum foil (using the emissivity ratings on Wikipedia lol)? I can see cost of said material as one downside but what about putting them in high dollar inserts? If mass has to be factored in then take out the aluminum foil. Wouldn't the two remaining materials be a better option vs soapstone?
