couchburner said:
I'm a little confused. Can someone tell me in simple terms and very briefly the different setups to heat dhw with wood stove. The stove I just bought has a built in DHW coil. So the way i understand it, I will need a sidearm heat exchanger at my dhw. Fill the stove with water and it circulates to the dhw, thru the heat exchanger, and back to the stove in a closed loop.(no new water in or out of this loop) And I am guessing I will need a circ pump for this line as my dhw is quite a ways from my stove.
I have two DHW tanks, one is about 30 gallon and one is about 80. The small one runs the kitchen. Could I hook these two DHW tanks up in series. And if so which one first? The small one is close to the boiler and in line with the big one which is about 90 feet on away from the boiler
Since you have a DHW coil in your stove, you should not deed a sidearm. The sidearm is used to heat water when you don't have a DHW coil. You will need a mixing/tempering valve somewhere in your DHW system to make sure that water delivered for use is not too hot. The water coming off the DHW coil could be scalding hot, up to the water temperature in your stove.
You may or may not need a circulating pump, depending on how hot you keep your stove, how well the DHW water coil works, and how much hot water you use. Usually domestic water pressure simply moves "cold" water through the DHW coil when a hot water faucet is turned on, thus heating the cold water to hot, and then delivering the hot water to the faucet.
How you plumb the hot water tanks for interim storage becomes a separate issue, and can get a bit more complex. It seems to me that, ideally, you would have a circulating pump and control system to circulate hot water from storage through the DWH coil when the stove is hotter than the storage, thus heating the storage. You might consider a differential controller for this.
In all cases hot water for use would be drawn from storage using the domestic water pressure. As hot water is drawn from storage and storage temp drops to below stove temp, then the differential controller would start circulating storage through the DHW coil to heat storage. Hot water from the DHW coil should be supplied to the top of the storage tank with return to the DHW coil from the bottom of the storage tank. Hot water for use from storage should be drawn from the top of the storage tank, with new water resupplied to the bottom of the storage tank.
How you plumb the two tanks is a matter of choice and may depend on which one you want to have priority, that is, which one needs to be sure to have the hottest water.
Since I do not use this kind of setup, I'm speaking from my own logic. Others may have better advice.
