Glass in that porch and add some thermal mass... or some kind of solar idea in that general direction.
Wood stoves need to get up to a minimum temperature to work... below that you get things condensing on the walls like water, soot, creosote, or some unpleasant combo of the three. Stoves come in sizes and the one you have looks like it has many cubic feet of firebox and many many square feet of heat-radiating area... all of which need to run *above* the soot-condensing temperature. LOTS of heat. It is tempting to think you can just burn a handful of wood at a time to get the heat you want, and in fact you can... but the stove will not be happy and will gunk up and/or rust inside. Meanwhile it will be using up a lot of living space in your cabin.
You are headed in the right direction in looking to swap that interesting old stove for something better suited to your heating needs.
You wouldn't use a 400hp diesel to run a 10hp water pump... it'd work but the rings would clog solid with soot in no time... this situation is similar.
Eddy
Eddy
