Gone for the day, sorry!
M'kay.
1. Smokey, we've fermented plenty of things around here, most of them intentionally, but we do not distill. I sometimes wish, in a nostalgic fashion, that it was legal to distill, not because I think I have anything to offer the world in terms of distilled beverages (I don't) but because I am afraid that we are losing old skill sets as the old timers pass away. I don't wish it enough to break the law though, so I don't go anywhere near distillation. Besides, I took chemistry in college and I about had my fill of flammable substances and open flames. Add blown glass and joint grease to that and you have an organics lab! and I'm so done with that part of my life.
2. I'm probably singing to the choir here but keep those pickled eggs in the fridge. I'd have to go digging around online but I think I read a report of botulism poisoning from pickled eggs kept on the shelf. As I recall, the vinegar solution didn't make it far enough into the egg to pickle the yolk, or something like that.
3. We are, budget permitting (and with the energy issues on the national and international agenda, it may be a budget requirement) about to investigate some serious insulation. We don't know if it's possible to blow insulation in our exterior walls but we're gonna find out.
4. Back to the original question, with an offshoot: I sort of understand the operational flowchart of the pellet stove and I sort of don't. I know that the OAK supplies outside air for combustion. I have pulled the sides off and the motor with the fan out of the exhaust pipe port to do The Big Clean, and I have cleaned that little paddle-wheel looking fan on the other side. I don't know what the paddle wheel fan does. What blows or draws combustion air through the burn pot? The convection tubes at the top of the fire box, the ones that blow heat out into the room, where do they terminate on the other side? Are they drawing room air in to be heated? (I would guess so...) and if so, where is the room air drawn inside? Where does the damper fit into this equation? Literally, where in the circuit? I know what it does- but where *exactly* in the circuit is it placed? Is it controlling the air flow from the OAK? and this leads me to the point of this point:
5. How are the damper and the OAK related? I ask because, while our damper has 6 marked settings, "Low" to 1, 2, 3, 4, 5, most of our flame variation occurs between "Low" and 1. No kidding. The whole "set the damper" exercise when one sets the damper at the point at which the flame changes from lazy to active- that setting on our stove is between "Low" and 1. Beyond 2, the flame is almost blow torch or bunsen burner quality.
No matter where the damper is set, we have a "burn cycle" in which the flame ranges from almost out to a nice, white, tight blaze. When a fresh load of pellets is delivered to the pot by the auger and it catches fire, it burns high, tight and bright until the pellets are almost gone, down to cinders. About the lowest we can set our feed and have the stove stay on is between 2.5 and 3. At 2 or below we risk the stove going out because the pellets in the pot burn completely to nothing.
My guess is that we have a quick, hard burn because we have so much fresh combustion air coming into the burn pot from the OAK, with its short excursion to the outside. Also, the exhaust vent is a horizontal short excursion to outside, with one 45' elbow inside the house. My guess is that the draw is pretty phenomenal.
6. Per this thread and another thread in which I inquired about setting the damper, I'm trying to set the stove to wring the most btu's out of the pellets, and also trying to send as much of that heat as possible into the house rather than out of the exhaust pipe.
Am I getting this quick combustion due to the short excursion of both the exhaust pipe and the OAK? Figuring this out will go a long way toward us setting the stove at the right feed rate and damper settings.
7. OH, and the blower fan- I know it pushes heated air out of the stove and into the house, but I swear, the higher we have our blower set, the more active our flame seems. How is that happening? Or am I imagining that?
8. Our pellets don't "dance" in the burn pot, no matter how wide open we are running the stove. I don't think that's a function of how hot the stove is running; we can have it blazing away but the pellets don't popcorn. Is that a function of the engineering of the Napolian "Dancing Flames" burn pot?
