I local Chimney guy told me he uses and recommends an 8" Poly brush for 6" SS round liners. He says it does a way better job than a 6" brush and is not hard when using the rods. Anybody else agree??
No i do not agree, I just bought and used a 6 inch poly brush in my 6 inch liner and it was hard as hell to push through 18 feet of liner to the point it got stuck in a bend, after some cuss words and pulling really hard i freed it up. I took the brush to the garage and trimmed up the brushes bristles. I went and swept my liner again and it was much easier to push and pull the brush through the liner. I didnt trim it too much because i wanted it to scrape the sides. The end result the liner was clean from top to bottom.
I can't believe you could even get an 8 in poly brush down a 6 in chimney! I had to trim my 6 in to get it to reverse in my 6 in chimney. The first time I put it down the chimney I thought I was going to pull something lose getting it reversed to come back up. Buy the correct size for the chimney. It will do just fine.
Thanks, guys - that's enough to convince me. Maybe it depends on the brand - but after hearing those stories I'm gonna order the 6" brush. I'm trying to get away from my old 6" steel brush - it's hard to pull through the flue and with brand new pipe, I'd rather use Poly.
But I will really miss being able to clean a warm flue with the steel brush - I hear the Poly melts easily.
Not to hijack, but would tying a rope on the end and dropping it down as a "rescue" for a stuck brush / broken rod work? anyone else do this? I have a cleanout I can pull the rope from if needed. Doing my first sweep this week - 6" ss with 6" poly brush.
