Does anyone use a buzz saw any more?
We cut most all our wood with a cordwood saw and have done so for years. There are a few things that make it all work out nice. First you really need at least two people, with one person you tend to reach across the spinning blade and that is no fun.All our wood is cut and split in 4' lengths so two cuts gives you three 16" pieces. About 6-8" in diameter is about max.We pull the tractor along side the pile, start sawing and tossing into the truck. You can really work up a lot of wood in a hurry. Also in my opinion, 4' split and stacked wood drys quicker.
How do you split a round that is 4 feet long? I've never tried, but I imagine a Fiskars couldn't even do that...
I had a buzz saw rig that I bought in the late 80's and used whenever we had alot of pole length stuff to cut. I sold it last summer. I had an old Ford 8n tractor that I hooked a belt to to run the buzz rig. The tractor was in need of a major overhaul, so sold it and buzz rig. Also was getting to the point where no one around to help, so it was getting dangerous.
Dave
I am lucky enough to have a 4' splitter, but you would be suprised how easy you can split 4' by hand. It works best with straight frozen wood. You let the logs lay on the ground,stand with your legs on either side of the log and start swinging. Usually it will pop after a couple of swings.
Parents have an old one of these rigs out at their acreage.No blade guards,period.Just the frame/wide pulley setup for wide belt.Has a large 20" diameter 2" thick cast iron flywheel/counterweight with a few 3/4" partially drilled holes for lead weights just inside where the belt pulley is.They bought the place in 1981,older couple who sold it to them originally owned the 10+ acres of oak/hickory,it was part of 40 acres of timber used as a woodlot on their Century Farm.
Story I was told that the saw rig dates to the mid 30's,still has the original babbitt bearings, oilcups,hex nut & heavy washer on the 1 1/2" axle. is a bit stiff,but will turn with some effort.No blade (it wouldve been stolen years ago,if left on there).I have a 26 1/2" 68 tooth one hanging on my wall in family room next to a 100+ yr old Disston 5 ft 2 man crosscut however.
Kinda cool to see the old beast still out there next to the shed.Every few months I pour a bit of used oil on the oilcups/axle & spin it so it dont freeze solid.
http://m.youtube.com/index?desktop_uri=/&gl=US#/watch?xl=xl_blazer&v=ilOdT-0n76A
I hope that link works. If not, try googling "wippsage" and/or search you tube. The Europeans seem to be be using a safe 1-person buzzsaw. Look for the lutz Germany video, on you tube, they show one woman cutting up firewood. :) One more attempt with the video:
Links did not work but after googling it I found it okay. Looks like a good idea.
I have two buzz saws one is three point hitch that runs off the pto threw a gear box to pulleys and belts and the other one I build from scratch it is also three point hitch but has a 13 hp Honda engine that runs it. We buzz saw hedge wood all the time.
Those are cool. So much nicer than the old unguarded beast Granddad & my Uncles used.I imagine the freight from Germany would be outrageous with no US distributor/dealer though.
BurnMeOnce said:
Hey Dennis - One more time, if you are still interested. I posted the other YouTube links from the wife's iPhone...that silly thing messed up the links.
Here is one YouTube link, a guy using a big ole circular saw to cut up firewood http://www.youtube.com/watch?v=YnlqHyVnYbE&NR=1
Here is the dame, cutting up some firewood http://www.youtube.com/watch?v=Ctw17-Sqcrc
Nice looking saws. Sort of makes me want one! If only they were easier to sharpen. That would help a lot. I sharpened too many of those things already. But, if somebody had the saw and a nice powered jig for sharpening, that would be a nice saw to own. For sure better than those with no guards!
Thanks for posting that.
Here's the old beast out at parent's acreage.You'll see a random pile of various scrap iron on an old pallet on the back side,with an outer drum from a clothes dryer just behind the table...That's part of my stash,have some heavy gauge 1" to 2 1/2" pipe on the ground nearby.
  • [Hearth.com] Does anyone use a buzz saw any more?
Last 2 pics
My father just picked up a buzz saw from a family friend. After looking at the saw and thinking it through, we decided that it would best serve as a conversation piece in our new sugar shack and we would continue to use our chain saws......
Remkel, why not sharpen that thing and give it a try? You might find it works quite nicely and a bit faster too.
