I have no smoke coming out, these are pretty much red hot COals that crackle when you move them and they give off a tremendous amount of heat. is smoke pouring out indicative of carbon monoxide? or would that just set off the smoke alarm?
Well...yes, but the flip side to that is you don't have to see smoke for Carbon Monoxide to be present. I state this because I don't want anyone to do a take away of "No smoke = No CO".
The safe/unsafe argument really comes down to the draft of your system. Will it vent the CO or will it spill into the living area. This will be unique for each install/ stove/ day of sooon phase.
I sure as heck wouldn't be doing it without a properly operating CO detector close.
I've thought about it too as well, but again the CO2 thing freaks me out. Plus I get just about as much heat from the stove after 15 minutes when all the wood from the reload is caught and the stove top is up to 500-600 degrees.
Ok, so some ore questions, there are wood stoves that have screen capability where you take your door off and enjoy a more real feel of the fire. What's your opinion on that? What about open fire places, isn't there some similarities?
Just asking.... Also, I have co/smoke detecter about 22 ft away in sae room that I heat with it, thanks for the replies......
my stove advertises a screen so you can open the front and enjoy it like a fireplace. It is a downdrafter,,,don't know if that makes a difference.
My chimney system is blah due to an offset box so it sounds like my concerns were legitimate.
you could open your door when there are flames and smoke. If the flames and smoke continue up the chimney,,,i would think the CO went too. I don't see why it would be any different when only coals exist. Draft is draft.
yes, that is why i thought if you try it with flame and smoke on your stove first,,and it drafts fine with the flame and smoke,,,which you can see visually,,,that same setup should also have draft with the coals,,,when you cannot see the draft, due to no flame or smoke.Remember there is a huge variation of installations even here on hearth.com. What works for one does not mean it will work for all. It's risky business to suggest this as a common practice for many.
