karri0n said:
As a quick recap to the OP, Your best bet right now is to try filling the stove with a couple kiln-dried firewood bundles from the grocery store or home improvement store, letting it burn wide open for 15-30 minutes, and closing the air mostly down to see what your result is.
I'm not sure I'd trust that as a completely accurate test.
I have a friend who runs three firewood kilns for bagged wood. He told me that they get it down to 6% or less, but then it climbs right back up once exposed to the ambient relative humidity.
Sounds reasonable since we all know that happens, but then he told me that it gets condensation in the bags and gets moldy in storage.
Not truly kiln dried.
I haven't seen his operation, but I know from 30 years experience as a woodworker that you can leave real kiln dried lumber in plastic until the cows come home and it won't get moldy on you.
He won't listen to me because he makes money on the operation (he runs a sheltered workshop for retarded folks), but I know he's not doing it right. He says he uses a moisture meter on the end grain, but that won't tell you anything. I told him to split some chunks and get a reading that way, but he just changes the subject.
The moral for me is that maybe you can't trust kiln dried firewood to be any drier than you make it by leaving green wood in the stove room for a couple of weeks. His stuff is probably getting case hardened by raising the heat without leaving the humidity up there in the beginning. That will trap much of the moisture inside and it will dissipate inside the bags. It has to be a fast operation in order to be profitable for producing firewood, and real kiln drying (as in for furniture grade wood) takes time.
They use they same kilns for their pallet making operation, and I used to get all of their scrap I wanted for free. Sure, it burned fine because it is cut thin compared to firewood, but it always had a damp feel when I first got a load. Not like kiln dried hardwood you'd buy at a lumberyard, and not as dry as a well used pallet either.
Maybe other operations are better, but after reading a few posts about folks going out to get store bought wood and still having a problem, I suspect this may be the norm rather than the exception.
