If you've ever wondered why people on here tell us that wood needs to be well seasoned to burn efficiently, here's a story that might illustrate just why they tell us this... over and over.
I'm a new burner. We bought 3 cords of "seasoned" wood in October that was cut in December of '08 right after our big ice storm here. That's pretty much a year, right? We figured it must have had a least a little time to dry out. We didn't get our stove up and running 'till the first of Jan., so the wood sat for a couple of months. Half of the wood was stacked in our covered outdoor porch, the other half was out at the side of the yard stacked on 2x4s uncovered.
Well, we just finished up the cord and a half that had been stacked on our porch. We saw that it only burned so-so, since it really hadn't sat that long, and it was clearly not checked or grayed to begin with. We could also hear the stuff sizzle. Never-the-less, we heated the house adequately, and all was marginally well... until we had to start using the wood from the yard. With this wood, the fires had been smoldering much more, and good hot fires were taking considerably longer than before, if we got them going well at all. We presumed this was because it was the wood that has been out in the yard, and it hadn't had the couple of months to dry off like the wood in the porch did. There's been a clear difference b/w the two.
But, that's not the real kicker.... Last night, after being frustrated by a sputtering fire, I thought of doing a little "test". Well, we have a dysfunctional fireplace in the other part of the house that has had these old splits of wood sitting in it since before we bought the house. That's nearly 5 years of sitting in a dry fireplace. I thought, "Let's give that wood a shot". This wood was all checked, cracked, light as a feather, and it felt like it would likely disintegrate as soon as it hit the fire. So, I threw a piece of that stuff in there, and here's what I found:
That sucker lit up like a ROMAN CANDLE!! It burned solidly, while the other 3 or 4 splits that had been in there for a half an hour could only choke. Not only that, but this single split of wood, not even that large, raised the temperature of my stove by almost 300 degrees in about 10 minutes! So, I watched awhile, and also saw that this split didn't even burn significantly quicker than the other wetter pieces of wood. I thought it would fall apart in minutes. GO FIGURE!
Moral of the story... believe your friends on here that tell you that really dry wood can make a huge difference in your stove's performance!
It usually turns out to be the wood or the stove is piped into a large unlined masonry chimney. Being my first year my wood is less then perfect but I was cutting/splitting/stacking wood months before I bought my stove thanks to this site.
