Greetings,
Does a universal flue collar adapter need to be used with the double wall stove pipe for the NC-30? Currently, I am using a stove adapter, attached to the adjustable double wall pipe, attached to the chimney pipe.
I recently used clear silicone which I had left over from the install to seal up known air leaks in the pipe connections. Since the sealing did has done what I hoped it would do, I am going to scrape it off and replace it with black high temp silicone (so it looks better). The double wall pipe will reach to the flue collar and settle down firm on it. I would like to use the least number of pieces as possible to minimize air leaks and use less sealer.
As always, your input is appreciated.
-Ray
-Ray
