Hello World,
I calculated the amount of fuel needed for the heating season based off usage so far. I wanted to post it here because I'm open to criticism, and it might help out a new burner who thinks a lot about if they have enough wood.
First, I tracked wood usage. I have been burring exclusively from a cord of Poplar/Aspen for this reason. It's just about gone on December 1st. I assumed a heat value of 18 million BTU for this cord of aspen.
I also tracked Propane use. My 500 gallon propane tank has dropped from 76% to 72% since the house needed heat and I lit the stove on September 24th, this includes our cooking.
20 Gallons of propane at 91,502 BTU/gallon would be 1.83 million BTU.
Combined wood and propane that's 19.8 million BTU used so far.
Find out how much of the heating season has gone by. I pulled heating degree day data from my state climatologist's website. 8000 hdd per season with 1600 hdd as of December 1st. 1600/8000=20%
Finally use this to calculate your season's needs. 19,800,000 BTU / .2 = 99,000,000 BTU.
Since i started the season with 104 million BTUs in my 5 cords of ready enough wood I think I should be able to slide by.
I like this method because it takes system efficiency and internal gains (both highly variable) out of the equation.
I had some plans to try and get some of my recently split wood drying inside, but I think I just convinced myself (to Mrs. BK's great joy) that I'm close enough.
