Rob From Wisconsin said:From what I am hearing, there are a lot of people on this
thread who aren't familiar w/ a big "Cat" stove. The cat
naturally constricts the draft of the unit, because all of the
exhaust is being forced through it. 24 - 40 hr burns?? Sure
you can!! If you have a big enough fire box & are able to
turn it down sufficiently after the cat "lights-off". Also, you
would need to use the hardest of woods.
80% efficiencies?? Sure you can, especially w/ cat stoves.
Thicker, more expensive elements will lead to this.
P.S. - There are more ratings listings for Blaze King stoves
in Heartnet Stoves Rating section, under "Other Mfr."
(scroll through a "complete" listing & look for a "King..."
listing or a "KE..." listing). I think you will find a lot of
loyal Blaze King owners out there. If it were up to me,
I would have a Blaze King today
Rob
tradergordo said:According to Gunner the details of the 47 hour burn on the blaze king website report average btu output was 7,000/hr with stack temps of 200 deg. Tell us what catalyst lights at 200 degrees? Wouldn't running a burn like this though the catalyst completely clog it?
Rob
Roospike said:I'm looking to call a Blaze King dealer......See if he will give me a 100% money back guarantee...
Rob From Wisconsin said:tradergordo said:According to Gunner the details of the 47 hour burn on the blaze king website report average btu output was 7,000/hr with stack temps of 200 deg. Tell us what catalyst lights at 200 degrees? Wouldn't running a burn like this though the catalyst completely clog it?
Rob
Note that the the location that the flue temp was taken & recorded
was several feet above the Cat Element, and not thus not totally
indicative of the Cat Temp. Unfortunately, their current literature
is "cut-off" not revealing this test info. I do have the complete
brochure from a retailer with this test parameter info.
Rob
Shuuuuuuuuuuu............... be very , very quite .. I'm hunting Blaze KingGibbonboy said:Roospike said:I'm looking to call a Blaze King dealer......See if he will give me a 100% money back guarantee...
Make sure your Summit doesn't hear, it might not make dinner for you anymore, or solve calculus equations!![]()
Todd said:Once the cat is engaged at it's lite off temp it burns the smoke and stays lit even if the temp falls below the initial lite off. Cats can get away with lower stack temps because they burn all the nasty creosote making stuff before it reaches the chimney. When I look at my chimney while the stove is burning there is no smoke, just white steam coming out. Less heat up the chimney, more in the stove.
If I can get true 12 hr burns with my 2 cu ft firebox, the Blaze King with it's 4 cu ft fire box should get at least twice that. I believe!
tradergordo said:Todd said:Once the cat is engaged at it's lite off temp it burns the smoke and stays lit even if the temp falls below the initial lite off. Cats can get away with lower stack temps because they burn all the nasty creosote making stuff before it reaches the chimney. When I look at my chimney while the stove is burning there is no smoke, just white steam coming out. Less heat up the chimney, more in the stove.
OK - this is another great advantage for cats that (if true) I did not know about.
Questions:
1) Are there any studys or links that you know of demonstrating the temps at which a cat will reliably maintain combustion after initial light off?
2) Can you personally get no-smoke burns with 200 degree flue temps on a fully loaded firebox in your stove?
3) Why can't you get at least half the burntime Blaze King reports with your firebox that has half the volume? (you are only getting about 25%)
Questions:
1) Are there any studies or links that you know of demonstrating the temps at which a cat will reliably maintain combustion after initial light off?
treeman08 said:I am trying to decide today between the Blaze King Cat Insert and a Regency 2400I. The Dealertold me that yes they say in Idael conditions they get 47 hours on the King, and the insert I am looking at claims 20 hours burntime. He told me that he cant beleive in the real world, you would get those times, but he knows people that get 24 hour out of the king and 12+ hours out of the insert.
Todd said:tradergordo said:Once the cat is engaged at it's lite off temp it burns the smoke and stays lit even if the temp falls below the initial lite off. Cats can get away with lower stack temps because they burn all the nasty creosote making stuff before it reaches the chimney. When I look at my chimney while the stove is burning there is no smoke, just white steam coming out. Less heat up the chimney, more in the stove.
Questions:
