disconnected my oak
  • Thread starter Thread starter Birdie Golf
  • Start date Start date
Actually, cooling a dry fuel would be the reason that we put water on it when it's on fire.
And water is 1400+ times a better cooler than air ever could be except when it too is a liquid.
That cold air doesn't stand a chance of cooling that pellet fire enough to make a difference and in cold weather the fire will definitely have a better oxygen supply.
You need to look for any restriction in that system, an OAK is just another vent system.
This could be something as little is a glob of RTV that blocks part of the cross sectional area of the OAK or even a slightly crushed section of the pipe.
What end did you disconnect from the system?
Without my OAK hooked up, I get creosote build up on the glass of my stove. I would have to assume that the outside cold air is giving me a more efficient burn.
update......put a new screen on the OAK, one with bigger holes the original was to fine i thought, stove is running better now, not as well when its diconnected but better than it was before, gonna live with it because i dont like running it without
My stove has a small air intake and the screen needs to be removed when burning or I'd need to make a balloon screen to allow enough air to enter the OAK.
