This morning I was having a fire in my tiny house (stove installed last fall). The fire was dying down so I threw a little piece of split wood on as well as an old end piece of 1x6 fencing that was unstained but I am worried may have been treated. I was aware I shouldn't burn dimensional lumber but had been burning little pieces all winter since I had so much scrap left over from my build. I noticed the stove made some strange popping sounds and smelled a bit hot. I came down to discover it had turned from beautiful stainless steel to a rainbow color heat tempered steel. It did not seem over heated as I have seen it get too hot in the past. I need to check if there was maybe a small chimney fire but I suspect it was a chemical reaction from the dimensional lumber. I also noticed the stove gasket sealant I used to insert the t-pipe into the back of the stove seemed to be crumbly and looked kinda burnt. I am just sick because this 4 inch (nearly impossible to come by) s.s. flue pipe kit cost nearly a grand! Is there any way to get this steel back to it's polished state? Any thoughts on what happened?Should I replace the pipe? Paint it black? Just curious what you all have to say on this matter as I have only read about this occuring on the exterior pipe. Thank you and pardon the long winded story!
