Hi Everyone,
Interesting problem with my Quad Classic Bay 1200. My glass is getting really dirty....I know what is first in mind is to adjust the 'feed rate', but I've done that and it seems to be burning fine (no problem with buildup in the pot or anything, and the flame is nice and active...no 'slow licking tails', I also burn quality Energex Premium Pellets). The only problem I have is the glass. Here's a couple of things that I've noticed:
1) Only the right side gets dirty. The left side isn't 'eat off it clean' but it's nowhere near as bad as the right side. The middle pane starts to get real dirty the closer you get to the right side
2) Fly ash build up beneath the glass. This is normal from what I've seen, but it seems to be way higher on the right side. The pile on the left side when I open the door is maybe 1/8" and the pile on the right can be close to 1/2"+
3) The Door gasket/rope seems to be pretty beat up/dirty/compressed, especially on the right side.
So, above is leading me to believe that the gasket is letting cool air in, which in turn is drafting down the window causing the fly ash to be 'piled' and the window to get dirty (assuming that the air is cooler and causing the soot to build-up. Anyway, that's my current theory.
So, my questions:
1) Is my theory a bad one here?
2) If I do replace this, what do I ask for? Thickness, length etc? I'm sure I could find out if I pulled it out, but I'd like to call and make sure that the stove shop local to me (which doesn't carry Quad) has it before I do anything, since the stove is working...
Any help is much appreciated.
Thanks!
JP
So, my questions:
Thanks!
JP
