Oh and @St. Coemgen didn't mean to come down on you hard before, but seems you are not familiar with how a stove operates that is equipped with a catalytic combustor, which burns the exhaust gasses much like in an automobile. The advantage of the catalytic stove is that you don't need to have active flames and high burn rate for the combustor to operate and properly burn the volatile gasses. An EPA stove with secondary burn tubes need to maintain a much higher temperature (and active flames) to burn clean, like you said. With a cat stove, even with a very low smoldering fire, there is enough heat to function the combustor, and all those gases get burned even though the firebox is dark, and perhaps coated with soot from the smoldering firewood.
For example I took a couple pics last night after I got my stove up to temperature:
!["Dirty" Blaze King windows "Dirty" Blaze King windows](https://www.hearth.com/talk/data/attachments/188/188464-456ecbccea19388a49c6a4efc6f68ca0.jpg)
As you can see the door is heavily sooted, and no flames in the firebox. If you look very closely though, above the door you'll see the catalyst probe (might have to zoom in) its upside down but reads ~1200F. That is right above the combustor, so you can see there is definitely something going on in this stove despite the lack of fire and relatively cool firebox! The stove is full of 2-3yr css ash firewood.
And here it is:
!["Dirty" Blaze King windows "Dirty" Blaze King windows](https://www.hearth.com/talk/data/attachments/188/188465-6e8fed1e4ee90539a6584071c8142483.jpg)
I popped the lid up just for a couple seconds so you can see the combustor working, all that smoke from the firebox has to pass through this. It is very effective at combusting all the smoke.
The glass cleans itself fairly well with the next fire, usually just an inch or so of sooting remains in the bottom corners. I always wondered if the BKs could be run so the glass stays clean since I do often hear about the dirty glass, good to know they can be run fairly clean too if wanted. And nice looking stovese there @Ashful
And here it is:
