Hi guys,
I've got my new EKO 60. It has the draft booster fan on it that EKO is now shipping with their boilers. My question is this: I have hooked up the fan and it blows with tremendous force and truly creates a noticeable draft through the boiler when you open the door. Could I direct vent this boiler. As installed, I will have about 4 feet of double wall chimney that will go through the side-wall of my outdoor boiler shed, before turning and heading up the side of the building to above roof level. My question is, what if I just end it there? Maybe put a 45 degree turn down elbow on the end...... I know that garn does things this way, and the stack temps on the new EKO's is around 350 degrees, same as a Garn...... What do you guys think? If this worked, it would be much cheaper and easier than erecting a chimney....
