Treacherous said:Even mine on outy=2 (default) appears to work as well. I am going to change over to 3 since woodmiser had good luck with that setting. Auber is sending out a replacement buzzer. The 12volt version was accidentally sent to me instead of the 120V version. On mine the J1 output will activate at alarm, mute with > and then reactivate J1 again once temp has gone below AL1 and then back above AH1
Treacherous said:ajreid said:I've been thinking about doing this for a while. Tonight i finally purchased the equipment to do it. Possibly next weekend Ill have it operational. I'm going to try to have my blower on the stove turn on as well as the alarm on overheat.
Even thought about a fire alarm horn strobe. Lot of ideas nothing definite.
Good idea on turning on with an overheat.
I ordered up items the other day as well.
Treacherous said:I probably won't mess with the direct fan control option until my Lopi electrical component warranty expires next year.
Do you think it will be fairly easy to override the rheostat for full speed fan control that activates during an over-fire scenario? I still want to be able to use the variable fan control as well.
Have you considered using an on-delay timer instead of a relay? This would allow the temp to trigger the temp control output act as a debounce feature for instance if you used a time delay of 1 minute it would not trigger the alarm until the output from the temp control went high for 1 solid minute and this would reduce nuisance alarms.. If you really want to take it to the next level buy a $135.00 PLC such as this one http://tinyurl.com/cp4j5c3 .. The programming software is free as long as your program is small and allows flexibility to change things easily once the I/O is wired.. Overall I am impressed with what you’ve guys have done so far..
Treacherous said:I got the correct 120V buzzer earlier in the week.
How are most mounting that? I was thinking of making some kind of bracket but short term might just just a zip tie or use some good old black electrical tape.
Treacherous said:You might be able to tweak the accuracy with section 4.2 in the instructions. So far mine seems accurate on the gas fireplace. Unfortunately my IR is back at cabin so won't know for sure until I get back over there. I've never played with these PIDs before so a little curve for me. They do seem to offer a lot of options in a small package though.
WES999 said:Why do you think it is low? Are you checking it with an IR thermometer?
It may be that the magnetic thermocouple just needs to catch up with the stove top.
I have checked mine with a hand held surface probe and another temp monitor and it is always pretty close.
Treacherous said:The thermocouple I am using comes in from the top of the magnet so I can protect the wiring since someone said there was a 500 degree limit. Is the wiring on yours protected above 500 degrees? My current reading is fairly accurate I just need to tweak the display somehow (if possible) to read the true temperature of 75 degrees higher.
WES999 said:If you are sure you controller is reading low you can program an input offset.
It is PSb on the config menu.
woodmiser said:Treacherous said:The thermocouple I am using comes in from the top of the magnet so I can protect the wiring since someone said there was a 500 degree limit. Is the wiring on yours protected above 500 degrees? My current reading is fairly accurate I just need to tweak the display somehow (if possible) to read the true temperature of 75 degrees higher.
Keep in mind that as soon as you get away from the stove, even a inch, temp drops dramatically so say your stove top metal is 600°... the air an inch above is much cooler. Your thermocouple wire should be fine. Not only that, my wire is in the path of the blower air.
