raybonz said:
Drove diesels when I worked construction and I found them to be noisy and need parts as much as any gas engine truck.. I wouldn't like to pay for a 16 qt. oil change nor to replace 2 batteries instead of one.. Injectors can fail as do glow plugs and diesels can be hard to start in cold weather and work best if plugged in overnight in winter so that adds to your electric bill.. Seems that gas engines last as long as diesels with less maintenance costs and gas is cheaper than diesel..
Good Luck,
Ray
My 2004 Dodge doesn't have glow plugs, doesn't have a CAT nor an egr system. And that is the way it came from the factory. As far as cold starts are concerned, that hasn't been an issue since the eighties. None of them need to be plugged in at all unless you are in below zero country.
This truck has two batteries and they are still the original ones.
Oil changes are 12 qts at 7500 mile intervals. That equates to a 6 quart change every 3750 miles or so... same as gas, not as often.
Not noisy since the stone ages.
I have owned my Cummins since new. I just rolled 113,000 miles. Before that I owned a GMC Duramax/Allison from new for three years. That was a nice truck too but it was an injector failure waiting to happen. They improved since. I would not touch a Ford diesel after seeing what they went through since 2003's sick.o Even the newest Ford designed 6.7 is having problems in the fleet when driven hard. I do like the old Navistar 7.3 though. That is a great motor.
When it comes to towing, the diesels murder the gas engines in hill pulling ability. The gas engines just fall flat where the diesel can actually accelerate. Nobody likes pulling a 10,000 pound load up a hill at 15 mph... which is what the gassers are like. The Ford V10 sucks when towing anything over 5000 lbs.
As far as Dodge and thier automatic trans issues... that was addressed in the 2003-2004 models when they beefed up the trans and torque convertors. Before that the torque convertors used to go and take out the trans. Ford also had auto trans issues. They would commonly go at 40,000 miles when worked.
I ended up trading my Duramax in for the Dodge because I just wanted a simple straight six grunt diesel in a truck with a straight axle front end. It sounds and looks like a 4x4 diesel truck should. Dodge has really come around with design and quality too.
I've also owned two Chevy's with the 6.5 turbo diesel. They were nice but the engine was more of a car diesel than a truck motor.
These are the diesels I owned...
1993 Chevy 6.5 Turbodiesel
(broken image removed)
1997 Chevy 6.5 Turbodiesel
2001 GMC Duramax/Allison
2004 Dodge Cummins
I have put some cash into the Dodge ... nothing broke.. I just wanted more power.
Here is my partial list of mods..
04 2500 4x4, QC SB SLT, 305/555
Trans...Goerend 48, Triple Disk Torque Convertor, BDFlex plate
Injectors...F1stix
Turbo..HT62/71/13 SS
Arp Head Studs
Power adders.. TST, Smarty
Fuel Pump FASS150
Intake Injen/Amsoil
Tires and wheels... H2 & Toyo OC M/T's
Suspension..Kore leveling, Defiant Dual Stab Sys, Thuren Trac Bar
Exhaust....5" RIP 6" SS TIP
Mag-Hytec, Carli Light Bar Hella's, Bushwacker, K3LA LocoHorn, Western 8.6MPV V Plow
And they make awesome plow machines..
