ansehnlich1 said:Drumaz said:I agree - The thing should be roasting!! I start mine up the same way when there are coals. Except that when I close the door, it idles around 350.
Well then, if your stove is idling at 350 after that, you definitely have a draft problem. That stove should be moving up to 500, 600+ degrees.
The Oslo takes I think an 11 or 12 mm socket to get into the draft control area. I've had mine off a couple times without a problem. You should be able to inspect in there pretty easily with a simple socket setup.
I think your draft or wood are a problem, maybe a combination of both.
I know my stove likes dry wood, the dryer the better.
I'm pulling it off tonite... and getting some of that kiln dried wood.
