BLIMP said:swirling flame vs vertical flame?
krooser said:We all must be real DA's getting excited over a flame in a pellet stove...God help us....
duh, when the wind aint not blowing!j-takeman said:BLIMP said:swirling flame vs vertical flame?
Vertical looks more real, When have you seen a campfire swirl like that?
Dell point is the most efficient so you win! More heat using less=good!
Delta-T said:krooser said:We all must be real DA's getting excited over a flame in a pellet stove...God help us....
duck's asses?
BLIMP said:duh, when the wind aint not blowing!j-takeman said:BLIMP said:swirling flame vs vertical flame?
if u heat house from the cellar & need a self igniter, u definitely winj-takeman said:BLIMP said:duh, when the wind aint not blowing!j-takeman said:BLIMP said:swirling flame vs vertical flame?
Yeah, But I can go down to the basement and see my stove. You have to go to U-tube to drool! Maybe I win? %-P
BLIMP said:if u heat house from the cellar & need a self igniter, u definitely winj-takeman said:BLIMP said:duh, when the wind aint not blowing!j-takeman said:BLIMP said:swirling flame vs vertical flame?
dumb asses! me included....Delta-T said:krooser said:We all must be real DA's getting excited over a flame in a pellet stove...God help us....
duck's asses?
BLIMP said:dont make sense to add cfm to a stove that has been engineered per design.
Gio said:Pook (Blimp) likes the Dell Point but we know he`d be probably try burning coal and logs in it anyway.
SmokeyTheBear said:Gio said:Pook (Blimp) likes the Dell Point but we know he`d be probably try burning coal and logs in it anyway.
Not to mention waste oil, nuclear waste, and manure.
Europa has patented burnpot which gassifies the pellets be4 the flame & claims higher efficiency due to less combustion air blowing thru the stove. the other is the standard burnpot & u can see embers fly.krooser said:dumb asses! me included....Delta-T said:krooser said:We all must be real DA's getting excited over a flame in a pellet stove...God help us....
duck's asses?
I ran a Franco Belge oil catalytic stove in my finished basement for 7-8 yrs (oil was cheaper then) which did a similar thing . It was great and produced good clean heat (knob adjustable) and required no electric but the truth was my oil furnace was a bit more more efficient , quicker to heat , and easier to use and required less maintenance.BLIMP said:Europa has patented burnpot which gassifies the pellets be4 the flame & claims higher efficiency due to less combustion air blowing thru the stove. the other is the standard burnpot & u can see embers fly.krooser said:dumb asses! me included....Delta-T said:krooser said:We all must be real DA's getting excited over a flame in a pellet stove...God help us....
duck's asses?
hang on to your wallet cause a new oil burner condensing technology has just developed which allows for venting with a pvc pipe & claims up to 99% efficiency. no oil atomizer gun involved.Gio said:I ran a Franco Belge oil catalytic stove in my finished basement for 7-8 yrs (oil was cheaper then) which did a similar thing . It was great and produced good clean heat (knob adjustable) and required no electric but the truth was my oil furnace was a bit more more efficient , quicker to heat , and easier to use and required less maintenance.BLIMP said:Europa has patented burnpot which gassifies the pellets be4 the flame & claims higher efficiency due to less combustion air blowing thru the stove. the other is the standard burnpot & u can see embers fly.krooser said:dumb asses! me included....Delta-T said:krooser said:We all must be real DA's getting excited over a flame in a pellet stove...God help us....
duck's asses?
I`m not saying the Dell Point does not have the most efficient burn but there other good pellet stoves that cost less , are self starting , and have good efficiency ratings too . That said the Dell Point technology is interesting but they really need to come up with a auto start system to get them out of that niche segment. But maybe they are content where they are..
u might wanna ask an engineering forum if the oversized blower will wear out prematurely due to the air plenum space of the stove= might need to make some holes?j-takeman said:BLIMP said:dont make sense to add cfm to a stove that has been engineered per design.
I got the BTU's but I need to move them better. Higher CFM will move more air at a lower temp. No hot totsies when you step on the vent. Same as the furnaces do, duh!
BLIMP said:u might wanna ask an engineering forum if the oversized blower will wear out prematurely due to the air plenum space of the stove= might need to make some holes?j-takeman said:BLIMP said:dont make sense to add cfm to a stove that has been engineered per design.
j-takeman said:BLIMP said:if u heat house from the cellar & need a self igniter, u definitely winj-takeman said:BLIMP said:duh, when the wind aint not blowing!j-takeman said:BLIMP" date="1283908336 said:swirling flame vs vertical flame?
I heat the whole house with my Omega. There are a few cool spots. For the most part the house is kept at 72ºF so we are the warmest with this stove so far. I am working on replacing the convection blower with a larger cfm unit to move more air and add duct to the stove. Best I can do till I can afford the pellet furnace!
Dell point planning a furnace?
