Defiant rebuild advice needed
STJP
54
North Carolina
Finally moved my Defiant 30 miles to my new garage...in a pouring rain. Having a small loader made it a bit easier to move. Stove legs are removed.
This stove has seen little use, but has been sitting in an unoccupied house for 23 years. I'm thinking I should rebuild it. Having never rebuilt a stove I'm a little worried about it. For today however I am going to get the wet ashes out of it and get a better look around. I'm thinking to order a gasket kit and tubes of gasket cement and stove cement. I have no clue as to the best products. I have looked at Woodmans Parts Plus and Mountain View Hearth Products.
Recommendations and advice would be very appreciated. BTW I do have the Defiant rebuild manual.
Thank you. [Hearth.com] Defiant rebuild advice needed [Hearth.com] Defiant rebuild advice needed [Hearth.com] Defiant rebuild advice needed [Hearth.com] Defiant rebuild advice needed [Hearth.com] Defiant rebuild advice needed [Hearth.com] Defiant rebuild advice needed
JS
IIRC. that's a fairly straightforward & easy re-build. If you use Rutland Furnace Cement & the correct diameter gaskets (5/16" armored gasket for the griddle), you'll be OK.
You will also need the threaded rod kit. If you can't find the actual kit,
1/4"-20 threaded rod & 1/4"-20 nuts will do.
Couple of cans of Stove Bright Satin Black & you'll be good to go.
Woodman's has all the stuff, part number for tie rod set is: 500-7497.
GREAT stove, Defiant III, same one heats my house. So love the top load, majority of Defiants didn't have that feature. Good luck!!
Dasky and Defiant3, thank you. Your response, info and advice are very appreciated.
As you can see in the previous pictures I had some cleaning out to do. Since the ashes had gotten wet during transport in a pouring rain and I still had the stove secured in my loader bucket, I washed them out. I also discovered and removed a huge rodent nest. I now have the stove on a dolly in my garage.
I assumed it needed to be rebuilt. I would appreciate you fellows looking at these new pictures and offering an opinion re the need for a rebuild. [Hearth.com] Defiant rebuild advice needed [Hearth.com] Defiant rebuild advice needed [Hearth.com] Defiant rebuild advice needed [Hearth.com] Defiant rebuild advice needed [Hearth.com] Defiant rebuild advice needed [Hearth.com] Defiant rebuild advice needed [Hearth.com] Defiant rebuild advice needed [Hearth.com] Defiant rebuild advice needed [Hearth.com] Defiant rebuild advice needed [Hearth.com] Defiant rebuild advice needed [Hearth.com] Defiant rebuild advice needed I still need to use a brush and vacuum to finish cleaning inside and out as well as a coat of stove paint. A good bit of surface rust, nothing heavy or difficult to clean off on outside. Don't think it will matter as much [Hearth.com] Defiant rebuild advice needed [Hearth.com] Defiant rebuild advice needed [Hearth.com] Defiant rebuild advice needed [Hearth.com] Defiant rebuild advice needed [Hearth.com] Defiant rebuild advice needed [Hearth.com] Defiant rebuild advice needed [Hearth.com] Defiant rebuild advice needed [Hearth.com] Defiant rebuild advice needed [Hearth.com] Defiant rebuild advice needed [Hearth.com] Defiant rebuild advice needed [Hearth.com] Defiant rebuild advice needed
on inside once in use. The stove was used very little and then sat for 23 years. By "used very little" let's say it had 20-30 fires. BTW the smoke shelf is removed for pictures. Apologize for screwing up pic insert.
Thanks again,
STJP
I'd say go for it. I've seen many in worse shape that were rebuilt.
I'd tear it down & have all parts sand blasted before reassembly.
You have no idea what condition the furnace cement between the
components is in & probably won't until you burn it.
It DEFINITELY hasn't been abused by the original owner, since
nothing looks to be warped. Mother Nature has been working on
it, but even she didn't beat it up too badly...
Thanks Daksy,
I am the original owner so it definitely has not been abused. Regardless, sandblasting is a great idea. Do you think sandblasting would remove all of the old cement? I am a little concerned if a commercial sandblaster would be "gentle" with the blaster and not damage the iron. What do you think and advise?
Thanks again for your reply,
STJP
It should be fine with any sandblast media. Cast Iron is pretty durable & a reputable operator won't harm the metal. If you have any doubts about the furnace cement that's still there, take an old flat head screwdriver & round the head off on a bench grinder. Use it as a chisel to clean the grooves.\ BEFORE you have the components blasted..
Excellent advice. I will talk with a sand blaster I have used for Jeep parts and wheels.
Now you've got me wanting to do my Vigilant as well.
Cheers,
STJP
Reactions: DAKSY
I needed to have the flue installed before I was able to rebuild the Defiant. Here are some pics of the DuraVent flue through the roof of my insulated 6/12 metal roof.
Cheers
JS[Hearth.com] Defiant rebuild advice needed [Hearth.com] Defiant rebuild advice needed [Hearth.com] Defiant rebuild advice needed [Hearth.com] Defiant rebuild advice needed [Hearth.com] Defiant rebuild advice needed [Hearth.com] Defiant rebuild advice needed [Hearth.com] Defiant rebuild advice needed
