Defiant Install Problem Found - Source Of My Burn Time Woes?
To add to the above, today was very windy. Other have mentioned it might be a negative pressure situation, but it's only ever happened today with all the wind. How does one go about running a wood stove when it's windy then?
Wanted to add an update. Dealers have been pretty much useless. But I may have solved at least the safety concerns. Installed a Vacu-Stack topper on the chimney which caused a steady updraft up the chimney. I can now light it, even cold, and the positive draft up and out pulls the initial smoke perfectly. Second, I used 800 degree rated black caulk to seal a spot where they installed the chimney flue into the flue collar a bit poorly. I also have a CO meter and am keeping a log. So far it is operating way better than before. Doubt I’m getting any better burn times, but at least safety concerns are handled.
