Dune - the input to the cylinder is 3/8". The restriction exists no matter what hose I use.Sure, I'll chime in, but then someone will kill the thread.
Jags is right and wrong. He is right that he has plenty of pressure but he is wrong to use a 3/8" hose on a machine whose entire point is to go fast, and don't forget Jags, heat is WASTE. Surplus Center sells most diameters of 2 wire hose in various lengths for very reasonable prices.
http://www.surpluscenter.com/sort.asp?catname=hydraulic&keyword=HHNC
The whole flow issue is absolutely relevant if I were running something like a hydraulic motor. Something that has no "end point" - it is dependent on flow and pressure. With a splitter the end point is wood split or ram stalled allowing the system to build full pressure. Pressure DROP is a non issue with this type of circuit (to a certain point).
