I have officially given up on HVAC installation contractors. My experience thus far is that either the pricing is out of this world, ($13,000. quotation for part of the job) or the service is bad. I waited 2 months for a return visit after one contractor spent one day stringing the wrong pex. We exchanged phone calls at least every few days and there were frequent made and missed appointments. until I finally reached the end of my patience. At least he did not charge me because he knew how bad he screwed me over.
So I'm now my own installation guy. Yes, in the depth of winter. I figure, well... I built a 1500 gallon masory insulated tank and it holds water, so I can do this too. My learning curve is going to be very steep.
Most people seem to use black pipe to plumb the boiler loop and the primary loop (where a primary is used). I just called a plumbing supply place to ask about Chlorinated Polyvinyl chloride (CPVC) as an alternative. They have used it for such applications. They even have fittings for adapting from the 2" boiler outlets to the CPVC via brass then copper.
According to one supplier it can be up to 60% cheaper than metal, though I doubt this.
The schedule 80 CPVC is rated as follows: Heat Deflection Temperature,°F at 66 psi = 217* (D 648 according to ASTM Test method). I don't know what the heat deflection temperature is, but I could guess that it would melt there.
Has anyone here used CPVC instead of black pipe. It appears easier to carry. Will it work?
I'll use PEX for the narrower pipes but there is a hefty length of 1.5" pipe with multiple turns and I'd like to simplify that part of the install if possible.
