Cut length questions
My insert isn't very deep and I prefer NS loading if I'm really trying to pack the stove. I cut about half my wood at 12" for that reason. I can do it pretty accurately just eyeballing it. The rest I cut around 16".
I was cutting with my dad one time and he cut a bunch of rounds about 6-7" long. I was like, "dude, wtf is this?"
Turns out he's not very accurate estimating firewood length.
Reactions: D8Chumley
I cut to 16 inches, more or less, and my chainsaw has a bar that is around 16 inches, so I sort of eyeball it while holding the saw up to the log. I don't really mind pieces a little too short. If I cut pieces in the 13 or 14 inch range, I can push them to one side, leaving a space for a few north/south pieces on one side of the firebox. My stove will actually take an 18 inch log, but if I try for 18 inch pieces and go a little over, then I have pieces that won't fit. Instead I try for 16 inches and rarely get oversize pieces accidentally.
This is true wisdom.
My thought process usually goes like this:
"Is this gonna fit? Let me try it...hmm....no...well, maybe if I turn it this way...and move this other one a bit...and then...oh chit it's already on fire."
Then it's GO time, and I can either close the door on it, or carry the smoldering piece of wood outside and leave it someplace where it won't start a conflagration :)
Lol! That's why I shoot for 16-18" lengths even though my stove will take 20" splits. It gives me a bit more leeway when cutting and I don't have to use a freaking T-square to make sure they will fit.
Reactions: edge-of-the-woods
You and me both! Our firebox is like 6" narrower at the back than the front, I feel like I am playing the most dangerous game of Tetris, when I'm trying to pack it full. Such a pain in the a$$. Next time I'm looking for something with a square firebox if possible.
Reactions: NickDL
My little Napoleon stove says it will take a 16 inch E/W but they recommend a 12 inch, which fits N/S. When I get wood I decide real quickly if it is close enough to cut in half for the N/S loading. If I get pieces right around 16 inches I do not cut them down.
Stove takes 22, so I aim for 20 or so. Many on here say wiggle room he's get fires going, and I concur. I still have a lot of stuff up to 26" from my last stove, so the barbecue chunk pile is growing. After next season l'l have a more uniform supply.
I used to cut 18" now I cut 19. Stove will take a 22" straight in I believe, so there is a bit of wiggle room there. Might go to 20 or even 21, if I can get my length setting mechanism on the processor to work a little more accurately.
oo.
I've read here about Europeans who split their wood to something like 3' long, let it dry, and then custom split it for their customers.
Yes. A lot do long 1 metre splits for drying, then cut to stove length prior to burning. Usually 33cm (13"), or 50cm (19.5") lengths (1/3 or 1/2 metre). It can be either automatically cut to length or many homeowners use a chainsaw "sawbuck" with a really long bar. Many times the 1metre splits are bundled for storage/drying so they can be moved by tractor.
This video shows the system very well. Im working on adapting it to my own firewood storage methods. I hate handling wood more than once, so any way I can reduce labour, Im all for. I will be using 50cm as opposed to 1m deep bundles that need to be re-cut though.
"homeowner" manual cut to length with chainsaw. This is the deluxe version, there are much more basic models and more advanced, fully automatic ones too.
My Jotul will burn logs up to 24 inches in length, but I usual cut to 18 and then fill in around the end N/S with smaller pieces.
