mepellet
I believe class a or at least the one I installed was rated for up to 1000 continuous use. I might be wing though. If that's right and the chimney is installed correctly, it shouldn't be dangerous.
So I gather from this that you have "never" darkened the glass on your stove, or when you run a brush down your flue you've never had any accumulated creosote to remove? If so it is quite admirable, however I wouldn't say it was normal.As most know by now this burn hot in the morning and burn off the sote stuff makes me crazier than nature did. One advantage of the two piece baffle, the only one, in the 30-NC is that anytime the stove is cold and the urge strikes I can slide one side of it on top of the other side and using a mirror and flashlight look up the pipe. And in seven seasons, including today, I have never seen any creosote in the pipe. After long night burns.
Hmm, well I've only been bringing my non-cat stove temp probe up to between 400-550F. 800F seems real hot, but I assume it's ok. If I am using good dry wood and typically cruising 400-550F, am I building creosote?
- 1000 deg and climbing does get the heart started a bit...For one thing, anytime we let the fire go out, and start it again, we are starting with a cold chimney. Anytime you have a cold chimney you are going to get more creosote condensation than normal, maybe not much, but you definitely get some
including today, I have never seen any creosote in the pipe. After long night burns.Click to expand...So I gather from this that you have "never" darkened the glass on your stove, or when you run a brush down your flue you've never had any accumulated creosote to remove? If so it is quite admirable, however I wouldn't say it was normal
I cruise in those ranges - good dry wood as well (ok the odd sizzler - but not often) and the chimney so far (4 years) stays very very clean. That's with a straight-up thru the roof install. The higher temps for me are more to do with startups. Interesting discussion here around whether you need that hotter burn every day, etc. - I never really thought about it, but for me, it's kinda moot as these hot fires on startup are just the way my stove / setup runs best
This is the point that I'm making, if the firebox gets dirty sometimes, and after a good hot fire it seems cleaner, then you are burning something off, that something is basically creosote. If you have it in the firebox, or on the glass then it goes without saying you'll have a little in the lower part of the flue too, and it will also get burned off the next nice hot fire you have.The start up is the dirtiest part of the burn but since the fire is one of the hottest after it gets going it burns clean, have you ever noticed the fire box is dirty at the first part of the burn and then clean as a whistle a little while later,.
Better advice is not to smolder the fire at any time, flue temp monitoring is the key to clean burning , older stoves more so.
Burning your stove hot once a day tends to indicate you are burning it too low the rest of the time.
.Even if you can't see the flue thermometer, or if you can't have one such as on an insert, there is one sure way to make sure you are burning right.
Use the glass on the stove - if you see full bright flame, then you are burning correctly. Obviously as you enter the coaling stage, the flame is gone, but so as well are the ingredients that create creosote.
Bright flame, clean flue.
Exactly. The flue thermos were a tool for stoves where you couldn't see the fire.
.No doubt and I dont need it but my flue temps are all over the place and its nicer for the wife.Oconnor and BB make a good point
I thought I was the only one stupid enough to do that.But having said that, for $15 and 5 minutes of my time, I get a nice sanity check (for me, anyway) - just another visual cue. Until I have a brain fart and run the brush down and mangle it.
fbelec, unless I missed something it sounds like you have a handle on the situtation and know what you are doing, flue temps look good, out side non insulated chimneys are tough to deal with.
Had a friend who had an outside block chimney and he could not keep the condensation out of it, I suggested he build a insulated chase around it and the problems went away and the stove worked much better.
Does this mean a metalbestos chimney is more prone to condensation since it's in direct contact with the outside air?
900 would make my butt pucker but my condar is way off after about 500 or so, maybe was only an actual temp of 750 or so with a 900 reading.When he'd light a new fire he'd let the Condor thermometer go right up to 900F. The needle was pinned. He'd let it fire this way for 10-15', then turn it down.
