Been in the BIZ for 9 yrs, now... I try to sway customers away from CAT stoves altogether, for both of our piece of mind...
Thats to bad.
Patapsco Mike said:summit said:pull out the baffle and clean from the bottom w/ flex rods.... also to consider: is there a cap on the liner? is it the one that came w/ the liner? often the standard liner cap is made like those for a prefab chimney: it has spark guard strips and/or mesh around it. this catches alot of flyash and soot bits and can heavily restrict the draft, even thought the stack itself is clean. i have swept alot of chimney setups like yours over the years, and usually a clogged cap is the reason for the smoke back (provided the wood is good and seasoned and the baffle is installed correctly.) also, if you had the chimney swept: I would verify the sweep didn't leave a pile of soot on top of your baffle... If he didn't take it out when he swept it this could be a factor as well.
Man, seems like a lot of "if your baffle" and "usually" and "provided the wood is" in the advice to that Summit owner too![]()
Let's be honest, there are a lot of if's and buts with any stove and flue setup. Having a cat or non-cat doesn't change that. In both cases there is a lot to think about.
SmokingAndPoking said:summit said:welcome to having a CAT stove: sure you can burn it forever on low, but I don't care how great the CAT is supposed to be: it all ends up as cresote in the end...
Umm, what? This doesn't make any sense at all.
Chopslide said:Ok it got warm enough to get on the roof (33f) I cleaned the flue cleaned out and inspected the stove... the cat seemed to be snug in its mount... bypass door seal looked fine I couldent find anything wrong that jumped out at me so.... started a new fire....at about halfway into the active zone on thermo closed bypass tstat on 3 let it rip for a half hour mabe more.. cat thermo is pegged.. climbed ladder to check stack and smoke.... not alot but smoking a little. I then turned it down to 2.5 and waited 20 minutes or so checked again and still smokin a little
I am burning mostly dougfir that was standing dead 2yrs back split and stacked 2yrs ago reading something like 14% on the meter.
my idea that the cat is ok is mostly from the fact that it will stay engaged for a burn cycle easily but that could be wrong as well.
Its about 32 now high pressure for the next couple days so it will be cold enough at night to let it rip a little and check again for smoke tomorrow
Todd said:Chopslide said:Ok it got warm enough to get on the roof (33f) I cleaned the flue cleaned out and inspected the stove... the cat seemed to be snug in its mount... bypass door seal looked fine I couldent find anything wrong that jumped out at me so.... started a new fire....at about halfway into the active zone on thermo closed bypass tstat on 3 let it rip for a half hour mabe more.. cat thermo is pegged.. climbed ladder to check stack and smoke.... not alot but smoking a little. I then turned it down to 2.5 and waited 20 minutes or so checked again and still smokin a little
What color is the smoke? Some newbie cat stove owners see white and think it's smoke when it's really just steam which is caused by high combustion efficiency.
pen said:Todd said:Chopslide said:Ok it got warm enough to get on the roof (33f) I cleaned the flue cleaned out and inspected the stove... the cat seemed to be snug in its mount... bypass door seal looked fine I couldent find anything wrong that jumped out at me so.... started a new fire....at about halfway into the active zone on thermo closed bypass tstat on 3 let it rip for a half hour mabe more.. cat thermo is pegged.. climbed ladder to check stack and smoke.... not alot but smoking a little. I then turned it down to 2.5 and waited 20 minutes or so checked again and still smokin a little
I think everyone has made that mistake before. Only way I learned this lesson was while being frustrated and looking at my "smoking" chimney I noticed that my neighbors propane hot water chimney had the same smoke! I then put 2 and 2 together to equal another even number.
pen
Chopslide said:todd I am seeing a glowing cat when the themo is up well into the active zone
I have seen nothing about adjusting the bypass door but am thinking it is the most likely culprit at this point... where did you see this video?
thanks all for the replys
Chopslide said:after checking out the video (thks BB) I cooled down the stove and checked out the adjustment on the bypass door... it seems to be seating well and I think I can rule out air leakage ( any major leakage)
checked it out w/bright flashlight and could not see any light at all
so I guess what is left is cat or wood problems I am still seeing smoke (small amount) thru all stages of my burn cycle so something isnt right
will be checking in with my dealer on mon then go from there...
myzamboni said:Burn wide open for about 15 minutes each day, and that will help prevent future clogs.
Chopslide said:5' single wall to ceiling..... 12' of double to roof jack.... 3' above peak.... all straight up I do burn at 3 for a while when reloading but stove gets hot pretty fast and have to turn it down before it gets to out of control
I have also re adjusted the door latch using the d bill trick but am not sure how hard it should be to pull out
thks
Patapsco Mike said:Just to make sure, you do know you have to push the cat lever all the way down, firmly, until you feel it lock- right? You can't just lower it, you need to give it a firm push until you feel it lock. If you don't do that last push you might not be getting a tight seal.
