dude that smoke coming out your chimney in those pics ain't a good sign. i'm still sayin you ain't burnin hot enough.
i think you're either cutting the air down too far, too soon, or something, or you're not getting that thing hot enough quick enough.
this here is from the Lopi Endeavor manual.....first thing it says is to operate this stove at a high temperature....
Over-Firing the Stove
This stove was designed to operate at a high temperature. But due to differences in vent configuration,
fuel, and draft, this appliance can be operated at an excessive temperature. If the stove top or other area
starts to glow red, you are over-firing the stove. Shut the air control down to low and allow the stove to
cool before proceeding.
Over-firing may lead to damage of plated surfaces. If you are uncertain of over-firing conditions, we
suggest placing a stove thermometer (e.g. Rutland® Model 710) directly over the door on the stove top -
temperatures exceeding 800° are generally considered over-firing and will void the warranty.
start with a clean chimney, then get a stove top thermometer and run that bad boy up to 700 degrees each time you load it before backing the air down.....
see what that does.
see what that does.
