The old EBT fed air into the boost manifold. When conditions were right, typically on a hot reload, you could get a large bloom of wood gas and extra air fed by the EBT opening. This could produce an unusually high peak temperature. Closing off the EBT on the older Summits/T6 effectively closes off the boost manifold. That has given us a more controllable top end but not a lot of change with flue temps. The new Summits have a smaller boost manifold opening and PE has moved the EBT to the secondary manifold. It is no longer temperature driven. Now it operates on draft strength, similar to a barometric damper. They have also added a lot more secondary ports. I would be curious to know what flue temps read on the new Summit with these changes. FWIW, our flue temps track pretty closely with stove top temps -100 at the peak of the burn cycle. This is with a probe thermometer on double wall pipe.
