Hi guys.
I spent this afternoon replumbing my sidearm on the hot water heater in the milkhouse in the barn. Got it hooked up so that it draws from the bottom drain fitting and returns into the relief valve opening. Got everything together, checked for leaks and proceeded to heat the water up. Now, the heater is a Reliance 606 Electric, 50 gallon. I had the breaker off and after about an hour and a half the sidearm had gotten the heater up to about 85F according to the thermometer in the hot water outlet. Ran some through the faucet to make sure the thermometer was correct....... So I kicked on the electric as we were gonna need hot water for chores soon.
Now, fast forward a few hours.... The electric has been on to the heater, in addition to the sidearm running this whole time. Thermometer shows 130F. I shut off the electric, but leave the sidearm running. We go in for supper.
Now, 2 hours later, I go out to see that the wood boiler was down to coals. Water was still 180F. I shut off the pumps for the house and barn sidearms and do some quick rewiring to set the system up for beginning to run off the storage tanks. (I don't have my relays yet to automate the system.) Since I'm already outside, I thought I'd run out to the milkhouse and see what the sidearm had gotten the hot water heater up to. I go out and see the thermometer is at 80F. Strange I thought, but then reasoned that maybe with the new higher efficency stuff, that the water wouldn't rise out of the tank to register on the thermometer. A quick touch confirms that the sidearm is HOT. So, I go and open the hot water faucet........ And lo and behold, the water IS COLD!! I go back and check and the thermometer is still at 80F, and that was ALL the hotter the water was too!
So my problem is where on earth can all the heat in 50 gallons of water go in a mere 2 hours while the sidearm is STILL RUNNING?
All the hot water pipes go to faucets, which were all turned off with no drips. No mixing valves or things like that where water could be back feeding to other places.. And while I know that the reliance isn't the best insulated unit on the market, I wouldn't expect it to cool off in 2 hours. Especially when the sidearm is still running..
I'm beginning to see why our electric bill for the farm is $300/month, even now that we're only raising a handful of cows and not milking full-time......
