It was warm a few days ago so I decided to let the stove go dead and change the cat gasket and bypass gasket. The steel cat was getting sluggish but I don't think that was because of the gasket. But since I've never replace either gasket in 8.5 years, I was way overdue.
My stove is rear-vented into the masonry fireplace, so I took the top-vent cover plate off for access. I immediately realized that I needed to pull the stove out to get a good angle at the cat gasket ( bypass gasket is straight down in the top flue opening but cat gasket is forward of that.)
Since I was into this thing up to my elbows, I decided to wait until my new ceramic cat got here, and not get in a hurry to re-install the stove. I ordered from firecatcombustors.com, Applied Ceramics. I said "Wow, only $90, great." Then I open the box today..it's only half the cat! Nowhere did they say "you need two of these." There was only one section in the pic, so my fault for not deducing that a full cat was coming. Still, in many instances today, they state the obvious so that even a cretin like me can understand...like "Do Not Eat" on a desiccant pack.
I mean, who the heck is gonna just replace half the cat?? Sheesh.
I also got half a cat for my SIL's Fireview for $99. So it's gonna cost me $20 more for each complete cat, than I could have gotten the steelies for, from Woodstock. OK, whatever, I wanted to try the ceramics again.
I had the original ceramic that came with the Keystone, but I'm pretty sure it was getting weak...so I didn't feel too bad when I broke it, trying to gingerly coax it out of the cast iron cat housing. DOH!!![shuteye <> <>](/talk/styles/default/xenforo/smileys/shuteye.gif)
I applied anti-seize to all the bolts as they suggest, even though most came loose easily.
I ended up with the stove down for three days so I had to heat with a quartz heater, with an occasional boost from the oven. Outdoor temps the last couple days and nights were fairly steady, 30-35, with some wind.
![20200205_141338.jpg 20200205_141338.jpg](https://www.hearth.com/talk/data/attachments/256/256647-6286959a5bc50fdae8986c6b165b406f.jpg)
Bypass gasket, and cat gasket behind it.
![20200205_182211.jpg 20200205_182211.jpg](https://www.hearth.com/talk/data/attachments/256/256648-2438ea983a127112d505443cb7d237f5.jpg)
Liner looked pretty clean, down low anyway.
![20200205_212747.jpg 20200205_212747.jpg](https://www.hearth.com/talk/data/attachments/256/256649-6f062926c8ee82bf473081f955bc9d58.jpg)
I put a longer 9" cat probe in, so that it would extend over the exhaust face of the cat. But it doesn't transfer the heat all the way back to the spring and it ends up being a flue-exit temp meter. I seem to remember that the digital probes like an Auber have an insulation sleeve and I was thinking that if I installed that to shield the shaft of the probe, maybe it would give an actual cat temp. I know a glowing cat is hotter that 800 degrees..![hmm ;hm ;hm](/talk/styles/default/xenforo/smileys/hmm.gif)
I have 1000 marked with a bent paper clip since the meter face is on the back of the stove, even with the fireplace opening, and I can't see it without a mirror.
![20200206_202150.jpg 20200206_202150.jpg](https://www.hearth.com/talk/data/attachments/256/256650-be8cbb9a23c021f81857b3d86627c63c.jpg)
Cat and bypass door back in, and the magnet and washer I stuck in there to hold the probe in position. I don't know how long that will stay in place (I think magnets get weak when heated,) but the probe isn't giving me a true cat temp anyway. When I get that insulation sleeve for the probe shaft, I'll drill a small hole in the cat heat shield to suspend the probe in position.
You can see the heavy-duty cast iron construction of the components in the stove in these pics, and in the service instructions from woodstove.com. At least a couple steps above what you find in a welded plate-steel stove. This stove can be torn down and totally every part replaced, so it could last forever. Like my old Pappy used to say, "It's had a lot of new handles, and a lot of new heads, but it's still the same old ax."![lol ;lol ;lol](/talk/styles/default/xenforo/smileys/lol.gif)
Adjust the bypass door tension a little on the loose side because when the stove is hot, it tightens up a bit.
![20200206_202537.jpg 20200206_202537.jpg](https://www.hearth.com/talk/data/attachments/256/256651-b536c684d66b378a3332e2bb6a088cc9.jpg)
Fired 'er back up a couple hours ago, and it's back up to my target in here, 70 degrees.![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
![20200206_225859.jpg 20200206_225859.jpg](https://www.hearth.com/talk/data/attachments/256/256652-9a7bae2a77e89c5d5d91937678d1754e.jpg)
