Really? So you have a back-up source of power for it, right?
You obviously don't know me. See for yourself: Show off your stove
That is a pretty stove...As for the vac, I ordered some popcorn from the Boy Scouts and it came in that tin!!
Nice stove. Looks familiar. So does the mechanics pry bar. I think I have the same one.Burned my first Ton so I was looking forward to giving the XXV a good cleaning with the help of my newly ordered Cougar. With this weekend coming up warm I figured a perfect opportunity was upon me. To my surprise I got home this evening to find my Cougar delivered and ready for action. Couldn't wait to open and check out the coolness. Wait! WHAT is this? Dang it! I ordered black. The lovely scenery might match some decor but not so much mine. I really want to use this animal but :: sigh :: must ship it back.
View attachment 88685 Go to Top
I got one and never use it because the shop vac with a drywall bag is waaaaay better!!
I had one (came with stove) used it 2 times the third time it found a glowing ember. Bad deal, house full of putrid smelling smoke and the end of the vac, not to mention the missus seemed somewhat paniced and pissed. Then I switched to a hepa shop vac and would never go back, way more vac power.
If you are looking for the real deal in soot vacs, this is what we use every day.
(broken link removed to http://www.mastercraftusa.com/products/Furnace-Boiler-Soot-Vacuums/Mastercraft-Sootmaster-Vacuum-Boiler-Furnace-Dry-Steel-Soot-Cleaner-660M-344192.php)
You can find them on Amazon and E-Bay once in a while.
Noticed it uses a cloth bag. Can you suck up hot ashes in that thing?
So true...I try to relax a little as my stove goes through shutdown (read a book...do another chore) and open the door to let things cool after shutdown for a bit. Then I brush as much as possible down into the ash pan so the ash that I actually vac is miniimum, mostly use it to catch any escaping dust/ash and to get the nooks and cranny's. By the time I'm getting at the nooks and crannys things have cooled down quite a bit.Please make sure your stove is cool before vacuuming.
I look at the vacuum being "capable" of sucking up hot ashes as more of an accident insurance sort of thing, rather than there's definitely still a few glowing ashes in there, I think I'll vacuum now. Does that make any sense?
NO Ash Vac is rated for Hit embers or Ashes. Read the manual. Only Warm ashes..
I used one pellet stove (Quad) for my Main heat for several yrs. Overshoot the needed temp, to give the stove proper cool down time.
No need to get in a hurry. Read some of Don2222's posts and find out what happens to those in a hurry with Hot ash.
How do you think your plastic Shop Vac would handle that same glowing ember as you sucked it up and then put the vacuum back in the basement? Call the fire department???? I have an Ash Vac and yes, it has less vacuum but enough to handle the job without fear of burning the house down. This same discussion goes round and round every few weeks for the years that I've been here. Two sides like Hatfields and McCoys will never give an inch.I had one (came with stove) used it 2 times the third time it found a glowing ember. Bad deal, house full of putrid smelling smoke and the end of the vac, not to mention the missus seemed somewhat paniced and pissed. Then I switched to a hepa shop vac and would never go back, way more vac power.
You'll like the vac. They are, as you probably have found out, noisy as HELL! I turn off my hearing aid when I use mine (a black one ). I also find that it really helps to give the filter a good shaking by removing the brass cover before each use.Well in my case I needed something with a small foot print. Up to this point I have used our Kenmore (bag model), which also served to clean the house, and it has done the job admirably. I will note here now : The stove has always been off for at least 3 hours after cool down cycle and confirmed completely out! I am sucking ashes into a paper bag with dog hair after all. That would smell something wicked no?
So it looks like i will be keeping the cougar pretty picture and all. I cannot for the life of me find the receipt so 1 ton cleaning first, black krypton will follow. Maybe I will get fancy and put a Hylian crest on it.
If anyone is interested I will pass along my experience although it seems most have cast your votes.
