I could not take the noise any longer, so I tore into the stove to see what is the source of the noise.
I took the sides off and discovered the noise is coming from the exhaust fan. I took that out and was SHOCKED as to how much crap had built up on the fan blades and behind the fan itself. After cleaning it, it filled a 1/3 measuring cup.
I also was surprised how much dust had built up in the squirrel cage blower motor. Got that all cleaned up.
I am guessing that the build up was causing the fan to run unbalanced, this making the squeal noise. That is the only thing I really changed.
My stove is now sooooooo quiet !
My question is why so much exhaust buildup? My pellets? Just the way it is? User error with damper? Any ideas?
Also, as Eric has said here before, be very careful when you take the exhaust motor off. The gasket is weaker than wet Kleenex tissues.
PS, Eric, I need to order a few gaskets. Do you have anything stronger? Would cork just burn up?
!My question is why so much exhaust buildup? My pellets? Just the way it is? User error with damper? Any ideas?
